Question about RTO 1:1.2 Mower Gearbox Brush Hog Rotary Cutter Shredder
Rotary cutter shakes
I have an JD MX7 rotary cutter and i hit a rock, Now the cutter shakes. I checked the blades and they don't seem to be bent or in very bad shape other than some pretty good nicks in the blades.The blade pan now wobbles, could the blade pan or the shaft be bent? Which is more likely? How can I check?
Thanks
    President:
  • 1,124 Answers
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Posted on Jul 14, 2009
Rotary gas mower bent crankshaft? Hit something really hard won't start.
This sounds like you sheared the key at the flywheel. The flywheel will have to be removed to replace the key.
Here's a how-to video -
LAWNMOWER BLADE Hit Something HARD Bent Blade SHEARED Flywheel key FIXED...
Oct 08, 2017 | Garden
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Blades hit each other when engaged
You got a bent spindle shaft,or a timing belt issue,or the wrong blades on the unit !
Nov 11, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
My JD JS35 mower hit a stump and instantaneously stopped. It won't start. Occasionally it will fire once. What might be wrong?
Hi, it has most likely sheared the flywheel key and thrown the timing out. Also check that it has not bent the blade or crankshaft. Regards Phil.
Jun 27, 2012 | Garden
CAN I ADJUST THE TIMING ON A 6.25 HP BRIGGS AND STRATTON ENGINE AND HOW?
The timing is key holding flywheel in place for timing. If you hit something, probably sheared or bent the key. Go to YOUTUBE, and on the line type in remove flywheel 6.25hp
Jun 03, 2012 | Garden
I hit a rock while mowing and now the mower is vibratating badly? What do I need to Do?
You bent the blade. Therefore you need to by a new blade and install it.
Good Luck!!!!
Wayne
Jun 14, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Instructions for how to replace the rotary cutter blade in fiskars rotary cutter, searched online but, not getting what I'm looking for... where does the washer go in placement...
I am trying to get something from Fiskarcrafts.com on the rotary cutter that you have. I will let you know when and if I get something. Also you might check out their website, sometimes they have online help.
Sep 21, 2009 | Fiskars Brands Donna Dewberry Rotary...
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
RTO 1:1.2 Mower Gearbox Brush Hog Rotary Cutter Shredder Logo
443 people viewed this question
Top RTO Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a RTO Heavy Machinery Expert? Answer questions, earn points and help others
