I have a kitchenaid washer model KAWS677EQO. I replaced the clutch and cam. When it spins everything seems to be out of balance and spins out of control.
  • 92 Answers
The bearings have worn is my guess.
Posted on Jul 15, 2009
When my kenmore 80 Series-model 110-29812890. Sta← Tap again to save rts spinning it starts jumping and shaking, but it is spinning and I have already balanced the load and the Washer is...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11029812890/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jan 10, 2011 | Washing Machines
Have a KitchenAid Prestige Top Load Washing Machine (Model: KAWs677EQO). It makes noise during the spin cycle and the drum moves when it comes to a complete stop after the spin cycle. Otherwise, it works...
I had the same problem 1 month ago, its probably the motor coupling for the direct drive. Its a small rubber Ring + a plastik drive. Its easy to change and not expensive.
Here the link for the part
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
May 01, 2010 | KitchenAid KAWS750L Top Load Washer
Drum seams out of balance
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Apr 23, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine tub banging against the enclosure!!
It's possible that one or more of the pads has come loose or broken.
If it's not the pads or agitate cams, you may have a bent or damaged drive tube.
See the Whirlpool PDF for commercial washers although the consumer models use the same basic parts.
Mar 02, 2010 | Kenmore Washing Machines
Have Sears top loading washing machine that tub seems very badly out of balance in spin cycle, even empty, loaded worse. Machine about 5 years old. All else works well.
Jan 24, 2010 | Kenmore Washing Machines
Model 2485-2300 Top Load Washer I have to
First, see the Sears Parts site for washer model 110.24852300 which I assume is your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24852300
Whirlpool / Kenmore top load direct drive washers use a clutch to start the Spin Tube which turns the tub.
They also use a Neutral Drain Assembly in the transmission which allows the washer to drain most of the water out before starting the spin.
Two possibilities:
First, See the following for how to remove the cabinet, pump, motor and transmission in order to check the clutch.
You don't have to remove the drum.
Check the clutch for wear as well as the springs. If the clutch is worn or the springs are broken, Sears has a "rebuild kit" for the clutch.
If the clutch is OK, the problem points to the Neutral Drain Assembly in the transmission.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
It also has a troubleshooting guide.
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Manually turning the drum apparentlthrows the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Nov 29, 2009 | Kenmore Washing Machines
I have a Kenmore 90 series Model # 110.28902790, during the spin cycle the agitator start to spin and then hangs up for a moment then tries to spin again.It keeps repeating this process while making a...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28902790
Please see the Whirlpool Service Manual for top load, direct drive washers.
Also see the Whirlpool Parts list for their commercial washers although the consumer models use the same parts.
The problem points to a worn Agitate Cam.
Whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
The cam is a two piece plastic part that lifts a gear above the main agitate assembly in the transmission so that the agitator doesn't turn during the spin cycle.
We had the same problem. The cams had worn enough that they weren't lifting the gear (less than 1/16").
They aren't expensive at all but do require pulling the transmission.
See the following for a description of how to remove the transmission.
You don't have to remove the tub!!
It may seem like a difficult job but it really isn't. It is a bet messy but it's a lot less expensive than a $170 transmission.
Nov 06, 2009 | Kenmore Washing Machines
I have a KitchenAid topload washer. The spin cycle does not work, you can hear the pump and motor but it will not turn. What could be the problem? Is it belt driven or gear driven? Sherry
First, see the following to determine if you have a direct or belt drive washer
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=50&osCsid=7a980a8b05b84ff3b7ee1c8ba46e2ae8
Whirlpool makes Kenmore and Kitchen Aid.
If you have a direct drive washer, the following may help.
The Kenmore / Whirlpool /Kitchen Aid top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If the washer agitates fine, the pump will drain but the washer will not spin, the problem points to the transmission / gearcase.
This is the Whirlpool PDF on installation and maintenance of direct drive washers.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kitchenaid) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Oct 28, 2009 | KitchenAid Washing Machines
When my washer goes into spin cycle it shakes real bad and makes aloud noise. I have leveled it but it is still doing it
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
We had the same (plus another) problem with an old Kenmore top load, direct drive,neutral drain washer.
Problem 1. Major gear sounding grinding during spin mode. Major vibration also.
After checking motor coupling (a bit worn but intact), drive block (you don't need a spanner wrench to remove it, a 12 - 14 inch pipe wrench works great) which was OK, clutch, seemed OK, we determined that the problems were in the transmission.
Two options, 1 spend $150 plus for a transmission.
2. Open it up and see if anything seemed seriously bad.
the problem seemed to be related to the agitator cam and cam follower not raising the agitator gear high enough (probably less than a 1/16th of an inch) above the agitator cam.
Found the right part number (Whirlpool part # 62580 / 81) which includes both the cam and follower. Bought one for about $10.50, installed it, put washer back together and problem was solved.
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Put the washer back together and I now have a happy wife. Everything works as it should.
NOTE. Fixing the washer takes a little mechanical ability (wrenches, socket sets, screw drivers, vice grips, short pipe wrench) and a solid desire to save some money.
All told parts cost less than $20 (I also replaced the old transmission oil with 80-90 weight oil from an auto parts store) saving over $125.
Sep 06, 2009 | Kenmore Washing Machines
Neptune FAV6800aww Will not go into spin
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Jan 22, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
