As per kenwood hit A=B to try to get rid of chirp and reset all menues when done keyer speed is also reset but cannot get it back to the higher speed
  • 3 more comments
  • k2ogt Jul 14, 2009
    withkenwood ts 870 per them hit A=B button to reset all menues when done it reset the keyer to slow speed (15) wpm not where it should be also reports of chirp and or drift harsh sound not clean signal from locals sound fine
    had reports of chirp on signal and harsh sound not clean was told by kenwood to reset by hitting A=B and reset the meneu but the keyer speed was also reset to0 the fault speed (15 wpm) cannot get it baqck to higher speed and chirp still there
    as per kenwood hit A=B button to try to get rid of chirp and when done it reset to the fault speed on the keyer (15wpm) cannot get the keyer to go any faster
    this is a kenwood transceiver model ts 870 hf radio nd if you cannot offer any solutions i will drop this service as quick as i got it
    have a kenwood transceiver model ts 870 had reports of chirp and rasby signal per kenwoods advice hit A=B button to reset the menue and when done it put the keyer at the reset speed of 15wpm not any faster cannot get it to go any faster
    President:
  • 2,777 Answers
Ok, slow down there, what exactly is the problem? You are getting a chirp sound from the transceiver? Does it chirp at regular intervals?
For the keyer issue, make sure you are in CW mode when you are trying to adjust the speed, otherwise it will not adjust any higher.
Please let me know.
Thanks
Tim
Posted on Jul 14, 2009
    Top Expert:
  • Computers & ... Master
  • 76,630 Answers
What pray tell are you talking about here, please explain model of equipment and what the problem is.
  • yadayada
    yadayada Jul 14, 2009
    u have a problem with the electronics of the unit, the noise is an ic circuit failing, pops and chips are the common symptoms of this.
  • 583 Answers
It looks like a settings problem bt the question is not very clear,please mention the exact fault with proper details so we can diagnose it properly and then solve it.
keep updated.
  • 3,230 Answers
This information about the problem is very little so can you please tell me some more details about; like -
make and model number?
Well, it seems like that the problem is in the motor of that player.
So check the motor first.
Thanks
I bought a car with a Kenwood KDC X 569 system and when I went to lay the remote down the system turned off I don't know if I hit a button or something but it wont turn back on please help
Kenwood Excelon KDC-X569 - Crutchfield
www.crutchfield.com > ... > All Car Stereos
Crutchfield CorporationThe Kenwood Excelon KDC-X569 CD receiver jumps out ahead of the pack, ... only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories ... HD Radio reception, and connections for building an audio system in your car. .... You can turn on/off this feature in the menu. ... Purchase accessories for this product.
Kenwood BT648U Car Audio How to reset a ... - YouTube
? 4:27
https://www.youtube.com/watch?v=NjzCs-WVPak
Feb 27, 2012 - Uploaded by Paul Tran
This is a video if you dont know how to reset a kenwood bt648u or any o... ... I was in dark ... what happened to ...
Dec 03, 2015 | Kenwood Car Audio & Video
I struggle to keep it back to normal my kenwood 480 hx anybody can help the left button i check that normaly give me menu the pf that changed also the bar problem plz help
Have you done a processor reset? It will clear up many problems. For some reason radios need to have the processor reset every so often. Lots of Ed going around the unit. Try that first.
Jan 04, 2015 | Kenwood TS-480HX Mobile radio, HF/6m, 200W
My 1995 toyota corolla blows clouds of blue smoke, but only when i hit speeds of around 50 miles per hour or higher. Its done around 130000 miles
this is an indication of worn bearings and worn rings as there is too much oil on the cylinder walls from excessive loss from the worn bearings that the worn oil rings cannot control the excess at high engine rpm's. Consider a recon short motor as it will be expensive to rebuild the engine.
Sep 10, 2014 | 1994 Toyota Corolla
Connect cw to IC-735
The ic-735 has to have the keyer option to use with a paddle, if it doesn't you will have to use an external keyer with it
Jan 17, 2014 | Radio Communications
At 70 mph the abs and parking brake light turn on and the the transmission loose presion and stop working, whe you stop the engine looks like the problem is reseted and work again, but then the problem...
Rear speed sensor fails at higher speeds. ecm cant tell what gear to go to and abs looses rear wheel speed. When you start over it sees speed till it hits the higher speed. Been there done that. :-)
Jun 06, 2011 | 2002 Chevrolet Silverado 2500HD
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
I can not remember how to reset the clock on my Kenwood KDC-MP332 MDS Fet 50x4
To set your clock on your Kenwood deck you must 1st have the deck in "stand-by" which you get to pressing the source button till just the clock displays, no music. Press and HOLD the "f" or function until you see menu, from there toggle thru the choices until you see clock adj. and use the ff/rw to set the hours and minutes and when finished hit the "f" button and your done. Now if you don't have a "f" button press the display button. Again Kenwoods hide the set-up menus really well. good luck. mark
Aug 20, 2009 | Car Audio & Video
Unlock security Code Kenwood KDC-MP3035
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Mar 26, 2009 | Car Audio & Video
How do i set the clock on my kenwood kdc-x492
you need to put the headunit in to STANDBY MODE then press he little DISP button to the bottom left of the volume knob. press it for a few seconds. then it will bring up a menu. hit the volume knob down a few times til you see clock set. then PRESS AND HOLD THE VOLUME KNOB IN THE CENTER then it will blink. press the volume knob up or down for hour i believe and left and right for minutes. Once thats done hit the src button again and its done!
Aug 21, 2008 | Kenwood Car Audio & Video
I have a cd stuck in my kenwood kvt 719 head unit and the touch screen controls for the dvd are not appearing.
Have you tried hitting the "Reset" button on the head unit?
The procedure is on page 7 of the owner's manual under the heading "How to reset your unit"
Here's the URL for the Owner's Manual:
http://inform3.kenwoodusa.com/manuals/KVT-719DVD.pdf
Per the owner's manual, you're supposed to call Kenwood technical support if the display doesn't correctly reset or come back on and/or if the disc won't eject.
Apr 14, 2008 | Car Audio & Video
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
