Question about Husqvarna Rose
Needle position is too far left
When I put the embroidery unit on and the U embroidery foot on, the needle position is too far left and it hits the foot, I am unable to embroider. HELP PLEASE!!!!
  • 3 Answers
Re: Needle position is too far left
It sounds like you have an alignment problem. You can try to move the needle over with the stitch button and run you machine by hand for the first go. If it jumps back over - you are going to have to take it in to be looked at. Good Luck!
Posted on Nov 19, 2007
0 characters
3 Points
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
I know how to attach my ruffler foot but my needle keeps hitting the plate .what do I need to adjust to keep the needle from hitting the foot
You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
Sep 13, 2014 | Sewing Machines
Quantum cxl timing problem
That will not be a timing problem. Most probably centre needle position has not been selected when using the straight stitch foot
Feb 15, 2014 | Brother ULT2001
Needle breaking
it's very possible that when the needle hit the hoop that it caused the needle bar to jump time
I would suggest that the machine be taken to a sewing machine shop to be checked to see for sure if it is the timing or something else since the needle is also hitting the throat plate
May 29, 2012 | Sewing Machines
Machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Apr 05, 2012 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Bernina Artista 640 - While embroidering, the sewing needle hit a pin and broke. Now that I have replaced the needle, the alignment is off. The needle point comes down onto the embroidery presser foot.
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
Nov 11, 2010 | Bernina Sewing Machines
When I turn my machine on the presser foot does
This does not sound good, you may have a failure in the eletronics. However it could be a loose connection inside the machine too. I think you need to see a service tech.
May 24, 2010 | Husqvarna Designer I
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into
the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,
left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the...
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Apr 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
130 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Bargain Box
Bargain Box
Richard Roth
Richard Roth
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
