Question about Lexmark Wheelwriter 10 Series II Typewriter
IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
IBM Wheelwriter 10 Series II 6783 Comes on with 6 Beeps and line spacing 1 2 and 3 blinking. I read the troubleshoot that says that it may be a printwheel issue but I replaced the printwheel and the issue persists, even after turning off for 30 seconds. Any other possible solutions before I have to send it out for service?
  • JDominguezNY Jul 14, 2009
    It does do the same thing with the printwheel out, is there someway I can check the sensor. As far as debris this unit is spotless and dust free.
  • Lexmark Master
  • 3,594 Answers
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
Posted on Jul 14, 2009
  • Dick O Reilly Jul 15, 2009
    Usually the LED goes bad, If you know how to remove the case the LED is on the backside of the printer held on by one screw, remove it and shine a light into the hole, you will get a different error if that is the trouble.
    DickyO
  • 4 Answers
This problem is commonly possible with a unit that the 2 AA batteries are (out). check for possible leak or corrosion and clean them up and install fresh AA batteries.
It always help to make sure that you remove the print ribbon, and pull back the hammer mechanism, and release the printwheel, and then reinstall all, by carefully line up the print wheel and put hammer back in place, then carefully install the ribbon and make sure it's also locked down with its latch properly, then when you turn on the unit, it should make only 1 beep and quickly get to ready position with one green light. Good luck there.
Posted on Nov 24, 2015
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
IBM Personal Wheelwriter 2 inoperative
sounds like a keyboard problem. You can try my fix under WW1000 or contaqct Geo Beyers Co. fpr KB rebuild
DickyO
Jul 16, 2012 | IBM Lexmark Personal Wheelwriter 2...
I have an IBm Wheelwriter 5 typrwriter. When I turn it on the line space lights blink and I cannot type or get the casette to move at all.
How many beeps? Which Lights? Blinking together or sequentially? These will help to determine the problem.
DickyO
Aug 04, 2011 | IBM Wheelwriter 6 Typewriter
I have an IBM Wheelwriter 10 Series ii typewriter that locks up with the 1, 1 1/2, 2 & 3 lights on the bottom right blinking. It will do nothing else.
If it types at first then locks up try a shot of WD40 on the silver shaft that the carrier slides on, if it still happens the carrier motor will need some to it is located under the case in the R. rear.
DickyO
May 26, 2011 | Lexmark Wheelwriter 10 Series II...
The spacing lights
Check to see that the printwheel is properly installed, then check for debris in the P/W area.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 10 Series II Typewriter Logo
1,041 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
