Question about RIM BlackBerry Bold 9000 Smartphone
Bluetooth headset pairing won't go away
I think I accidently paired my blackberry bold with my laptop as a headset. The problem is that whenever I make a call, it searches for the headset even if I close the bluetooth or delete the device. So, what can I do to make it not pair with any device as a headset.
  • 541 Answers
Right click on the bluetooth icon on the system try in the taskbar
goto addbluetooth devices,then it shows all the devices which are paired with your laptop and
click on the remove tab and restart your laptop
Posted on Jul 15, 2009
  • 26 Answers
You can disable blue tooth connections from the connections manager
Posted on Jul 14, 2009
My blackberry bold 990 cannot discover my samsung wep200 bluetooth headset, both are on and working but whether I try and "discover" or "listen" for the bluetooth, the blackberry never finds it. Help.
Is this Blackberry a corporate Blackberry, there may be some corporate policy blocking bluetooth connection. Check with your company IT support.
Are you able to discover and connect to other Bluetooth devices?
To put the WEP200 into pairing mode, the user must ensure the headset is off then press and hold the multi-function button for eight seconds, or until the LED glows a steady blue. Samsung uses the standard "0000" as the pairing code for the device.
Hope this helps
May 18, 2014 | Samsung WEP200 Headset
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
ATT BB Bold 9000 pairs with plantronics bluetooth headset fine but always drops connection when call is made
Make sure there are no other bluetooth devices interfering with the connectivity between headset and phone. Remove the Plantronics headset from the phone menu, if it's showing up. If possible, remove and re-attach the battery of the phone. Power off the headset. Pair the headset to the phone again and you should be okay.
Good luck from Headsets Direct!
Aug 11, 2011 | RIM BlackBerry Bold 9000 Smartphone
I connected my plantronics voyager pro to my blackberry bold and they connected fine (never asked for passcode) but there is a continual beep in the back round that makes the sound of the other call be...
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
May 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
Trying to pair VMX 100 - US Titanium with BlackBerry Bold. have tried three times and need assistance!
Make sure Bluetooth is turn on in your Blackberry.
Set the headset to pairing mode and choose find devices on your blackberry. When it finds the device, tell it to pair. The passcode will be 0000.
Mar 02, 2011 | Sennheiser VMX100 Bluetooth Headset...
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
RIM BlackBerry Bold 9000 Smartphone Logo
124 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
