Question about Toshiba Satellite A70 Notebook
Won't boot up , and don't have a bootable disk
  • 555 Answers
You are experiencing a total boot failure in loading your operating system due to some corrupted files then that is why you are not able to boot your operating system. Then i suggest that in order for you to boot up your Operating system you have to reinstall your operating or repair your operating system to have a fresh and ready to used new installed or repaired Operating system.
Thanks
Posted on Aug 07, 2009
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
Erc410m usb boot support
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Nov 17, 2012 | Computers & Internet
I changed my username now my password won't work this is on another computer.It ia a dell windows 7.It don't have a place for a disk
Go to the link below and download Ophcrack and burn the iso to a bootable USB Pen Drive... Boot from the bootable USB Pen Drive and let it do it's magic. You'll have the password shorthly:
http://ophcrack.sourceforge.net/download.php
Jun 30, 2012 | Dell Inspiron 1764 Laptop
Can i make a bootible usb for my dell diminsion 2400 i get a disskette 0 error seek failure
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
hope it helps
May 19, 2012 | Dell Dimension 2400 Desktop Computers
The laptop won't boot
probably the hard drive in your laptop is gone.
try booting ubuntu in live mode, so without installing it.
when the boot is completed, launch the tool gparted and see if it detects the hard drive: if it doesn't, you need to change the hard disk..
Jul 30, 2017 | Toshiba Satellite C655D-S5044 15.6" 2GB...
Laptop won't boot. Caps lock and numeric lock lights are blinking. It was working fine after I installed a new hard disk and restored the whole system using my recovery disks and backup. I installed...
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Jul 27, 2011 | HP Pavilion dv5-1004nr Notebook
How to format a pc
You need to create a bootable CD that will delete all of the information on the hard drive permanently. Here's a source for that software: http://www.killdisk.com/downloadfree.htm It's simple: after you create the bootable disk according to the instructions at the link I provided, load it into your primary optical (CD/DVD) drive and then reboot your computer and when your PC goes through it's Boot sequence it will automatically boot from the CD you created and then you just follow the prompts. NOTE: before you run create the boot disk, you should check your boot sequence in BIOS and make sure that the the primary optical drive is first on the list or else the boot CD won't work.
Apr 29, 2011 | Video Game Consoles & Games
Cannot boot to dos
You must be sure that the "USB boot" functionality is supported and enabled on your PC BIOS, otherwise the drive won't boot. Furthermore, be sure that the floppy disk you are trying to boot to is bootable in the first place, otherwise you can check some nice "boot disks" on (guess what?) BootDisk.com
Enjoy ;-)
Dec 31, 2010 | Teac FD-05PUB External Floppy Drive
Toshiba Satellite A70 Notebook Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
