Question about Boating
I have a 2001 24, monteray deck boat, volvo dp 5.0 . i went had dinner 2 hours latter on the way back boat started to give a rapping noise . only does it wile the boat is underway, i can bring it up tp 3500 rpm with the prop not engagued no noise . oil level ok 39psi temp good 155 degrees any idear
  • 5,687 Answers
It could be the u-joints under load in the driveshaft. It will only get worse and more expensive to fix. But it will be cheaper than a lower unit. You might want to check the prop hubs before removing the outdrive and check for lube in gears. Milky is bad. Good luck..
Posted on Jul 21, 2009
2002 Monterey with an 8.1 liter Volvo Penta running in it. I ran the boat about 6 hours over 2 days. When I was finished there was some oil in the water in he engine compartment. What could that be.
check engine oil seals , or you make a engine service oil change recently and squirm out the engine , also check the oil filter is tight , Maybe water comes from outside when navigating
May 26, 2017 | Volvo Boating
Weedeater riding mower with briggs and statton 19 cc 875 series engine won't turn over like its locked up. was running fine shut it off for 5 min and started back up and as soon as I went to engage the...
check oil level. Most likely no oil. If no oil, it ran, then got hot and as soon as you truned it off, welded itself to everything. You have a big boat anchol.
Aug 04, 2014 | Garden
Evinrude troubleshooting power trim
1. check all connections to the switch and pump and make sure they are not crossed.
2. Replace the switch
May 08, 2017 | Boating
91 chrysler new yorker will run the shut off and will restart latter on and do it aging
Camshaft position sensor? Good call but not close. The crankshaft position sensor.This is located on top of the transmission bell housing.
Feb 29, 2012 | 1991 Chrysler New Yorker
It is a 2007 Jeep Commander rocky mountain edition... My husband drove it to do some errands and then came home. About 45minutes to an hour later we went to leave again and it wouldn't start giving us a...
We have the same exact problem!! been happening the past year (about 5 times). Finally went all the way out friday, wasnt able to start after 2 hours, left work and went back sat and finally started after an hour. got it home and it wont start again. Why isn't there a FN recall on this problem that so many LOYAL JEEP OWNERS are having?!?!?!?
Feb 20, 2011 | 2007 Jeep Commander Rocky Mountain
MY 96 GMC SONOMA JUST MYSTERIOUSLY STARTED MISSING OUT BAD.
Check the plug in the cilinder that is missing for oil or carbon deposits, it may be the valves not closing tight.
I would have the compression on all cilinders checked and the fuel injectors cleaned and tested by a pro.
Good luck bud
Feb 28, 2010 | 1996 GMC Sonoma
1995 Volvo noise problem
humming noise?? a fan belt or something associated with it
Jan 01, 2009 | 1993 Volvo 940
1988 Volvo 740 cold condition, started short, cannot start again
Check the fuel pump fuse and fuel pump relay first, before replacing the fuel pump. The fuses and relays are behind the the ash tray, The fuses are labelled. The relay is on the left side of the relay rack, closest to the big round bulb out sensor. But before that, how about pouring some gas line anti-freeze or fuel injector cleaner into the tank?
Dec 23, 2008 | 1988 Volvo 740
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
Boating Logo
59 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
