Question about Troy Bilt 5.5hp Self Propelled Mower
My troybilt riding mower quits after 3-5 minutes of running. I can restart it but it then dies immediately. Suggestions?
    President:
  • 1,129 Answers
Remove the carberator bowl nut on the bottom side of the carb and empty out the gas from float then just put it back together there is debree or water in the float bowl.
Posted on Jul 14, 2009
My new 10.5 HP 30in. Troybilt riding mower just quit running after trying to go in reverse and forgetting to disengage blades.Cannot get it restarted for anything. Help?
One or more safety switches are not working. Engine off, put it in neutral, disengage the blades. Now sit on it, and try to start it. If that doesn't start the engine then take a multi meter and check for continuity on all the switch locations.
Mar 15, 2017 | HP Garden
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
Riding mower runs for short time and quits
check for spark when it dies the coil might be failing
May 21, 2012 | Yard Machines Garden
B &S 16hp engine on a riding lawn mower. Engine model #303777 Type 0015-02. 420 hours on tach. Under load engine hestates and dies. Will restart immediately, run a few minutes and die again. Without...
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Jul 07, 2011 | Garden
Simplicity Broadmoor only runs for a minute or two and then quits
Check both the air and fuel filters. Either being clogged would give this situation. It could also be dirt in the fuel line. Disconnect at both ends and blow them out. If none of the above helps, then the problem is likely in the fuel pump or carburetor and will take some disassembly.
Jul 07, 2010 | Garden
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine quites
Next time the mower quits, immediately unscrew the gas cap and try to restart it. If it runs straight away without a cap, you've found the problem - a clogged gas cap vent.
Clean the vent and you'll be able to run with the gas cap in place.
Good luck !
Marco
Jun 17, 2009 | Garden
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
402 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
