I suspect that the hot water flowing through the fixture is expanding one or more pieces involved at the swing point making the joint too tight to allow movement; I know of no way to fix this except to replace the faucet.
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help
thanks
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
When you get to the wii menu, with the icons. On the lower left hand corner, youll see an icon where you can access settings. Click on this, from there go to the option that says "Sensor Bar" If its not on the first row, Just select the arrows opposite each other on the sides of the screen. From there you can diagnose your problems.
