Question about Sony Handycam DCR-HC90 Mini DV Digital Camcorder
Firewire connector on camera is loose,repair manual needed
Hi,the plate which is holding both the usb and the firewire connectors are loose and i can t capture anylonger. i would like to open this up and fix it but without a service manual i m a little scared that i ll break it beyond repair or something.can you please help?i really need this camera,at this point i can t afford any other handycam...thanks in advance
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
U dont say what camera. Anyway go to e-bay and try to find the repair manual
Posted on Oct 11, 2017
SOURCE: sony handycam DCR-HC26 and mac not recognizing with firewire
mlkml
Posted on Apr 23, 2008
  • 7 Answers
SOURCE: Sony Handycam DCR-HC28
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Posted on Aug 22, 2008
SOURCE: dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Posted on Dec 01, 2008
  • 12 Answers
SOURCE: Video capture problems
Sounds to me that the bit rate on your PC or capturing device is not as high as that now available through the firewire ports. Try increasing the bit rate in your settings and see if that helps. Or have you always used firewire?
Posted on Jul 28, 2009
  • 497 Answers
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 15, 2009
Need USB cord
It could be a mini USB connector, but on Wikipedia, you can find all USB connectors with name and picture.
Mar 21, 2014 | Hello Kitty Sanrio - KT7002 - Compact...
I have a Panasonic NV GX7B and want to upload my movies on to my computer. I have a USB driver (VFF0155) disc which came with the camera and a VFA0363 cable to connect the camera to the computer, is this...
The USB VFA0363 is for transferring still photos, and cannot be used to transfer video. You need a 1394 cable (also called a "Firewire" cable). You also need a Firewire/1394 card in your computer. The 1394 cable can be purchased with either 4-pin or 6-pin connectors on either end. You will need a 4-pin connector on the end that plugs into the camera, and either a 6-pin or 4-pin connector on the other end depending on whether you have the large or small connector on your computer. The owners manual for your camcorder can be found here:
NV-GS3 Owners Manual
Jan 24, 2011 | Panasonic NV-GS3B Mini DV Digital...
Where can you bay usb cable for panasonc ds 55 camcorder to connect to pc.
This camera downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is usually used only for stills. This camera doesn't have a USB connection at all.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. However, while most PCs have a USB port, they seldom have a Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Jan 24, 2011 | Panasonic NV-DS55B Mini DV Digital...
How to connect to a pc, which cable is needed
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
You can download a manual from this link.
Nov 14, 2010 | Panasonic NV-DS29B Mini DV Digital...
How do i up load into a mac computer
There is a tutorial, manual and other downloads for your camera on this page.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will probably need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Nov 11, 2010 | Sony Handycam DCR-HC30E Mini DV Digital...
I'm looking for the driver of sony handycam CDR-TRV22E so that i can transfer the video to my pc. thanx.
You can download drivers and manual for this camera from this page.
Advice on how to do the transfer is on this page. (You need to select Mini DV)
Sony recommend using Firewire instead of USB to transfer video from this type of camera.
This camera has both USB and Firewire (DV) connections. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
Nov 01, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
How do you upload the Cassette Video into the computer?
This camera has both USB and Firewire (DV) connections. The manual seems to say that either can be used to transfer video. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
You don't say what computer you have. Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card.
A manual for the camera can be downloaded from this page.
The manual gives some details about connecting to a computer. More information may be available from the same site.
Oct 31, 2010 | JVC Cybercam GR-D90 Mini DV Digital...
What kind of cable do i need to use from camcorder jvc gr-d33u to pc?
This camera cannot send video to most PCs. It doesn't have a USB connector. There is something called a DV connector, but it is very unlikely that your computer has this. This is also called a Firewire connector and can often be found on the Apple Mac.
You can get an add-on PC card to fit Firewire connections to a PC. If you do this, you will need software (supposed to have come with the computer or you can use third party software) to do the transfers, and a cable JVC VC-VDV206U. This is however just a normal Firewire cable- though you want to be sure that you get the kind with a small connector at one end for the camera and a larger connector at the other (six pin) for the computer.
You can download a copy of the manual at
this link
Oct 20, 2010 | JVC GR-D33US Camcorder
Kodak Z740 camera unable to transfer pictures to computer. USB connector from camera appears loose and wobbly....is this something that can be repaired/replaced? Help! I've emailed Kodak but nobody has...
In this case, camera needs to send for repair since the USB connector loose. You may call 1.800.235.6325 for repair or go to www.kodak.com/go/itg.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare Z740 Digital Camera
The usb connector on my 500 gb seagate mseries is broken however i noticed that i can remove a plate on the bottom and replace the part my question is where can i get this part
There are 2 other solutions to this problem.
First way is to find someone that has the other module P/N 100452909 Dual FireWire 400 and use FireWire instead.
Second is to pry open the USB module and have the USB connector re-soldered or replaced. The connector is similar to many of the smart phones, so a cell phone repair shop could probably replace it. Heck you might even have the connector replaced with the newer Micro USB connector or ask them to solder the USB wire direct to the interface board.
Jan 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Logo
151 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
