Bissell ProHeat Shampoo Bottle Assembly 2101785 Logo
b
barbara taylor Posted on Dec 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the plastic cover over the rollers come off for cleaning
Thomas Hardesty
Level 2:
Habit-Forming:
  • Bissell Expert 159 Answers
  • Posted on Jan 30, 2016
Thomas Hardesty
Bissell Expert
Level 2:
Habit-Forming:
Answers
159
Questions
0
Helped
45581
Points
181
There are 4 screws holding it on. Remove the two on top and then lay the unit down and remove the two underneath near the brushes. The screws are self tapping screws so it's a good idea to use the same screw in the hole it came out of.
Need instructions on how to replace belt on the power brush accessory on a shark navigator
Hello, this is Ava with Think Crucial.
To change the belt of your Shark vacuum, you will need a flat head or a philips screw driver and a pair of scissors or a knife to clean your roller brush.
First, make sure to switch off your vacuum and is unplug from the power. In an upright position (vacuum), remove, empty and clean the dust cup. After cleaning the dust cup, lay down the vacuum horizontally on the floor to access the brush roller unit.
Using the appropriate screewdriver, flathead or philips (which will depend on the model of your vacuum), unscrew that holds the roller cover in place. When you lift the cover of the roller up and if it doesn't lift easily, don't force it because it probably means that you have missed one of the retaining screws. After you removed the cover, you will be able to see the roller assembly and the belt that drives it. If the belt has become worn, lost some teeth, or it has broken completely, you will need to remove the roller itself to be able to replace the belt. Clasp the end of the roller that is farthest from the belt between your fingers and lift it out of its holder. It should lift out very easily. You will then be able to lift out the other side of the roller that is attached to the belt and slip the belt on it. The other end of the belt, if it has not broken completely, will be attached to the motor shaft. That too can now be slipped off the end of the shaft.
With the roller bursh having been removed from the motorised head, I suggest you clean it. You may use a pair of scissors or knife to cut/remove the hair that are stuck. Be careful that you don't cut the bristles of the brush. Also, remove any debris that has found its way inside the roller cover at this point by using a wet towel or tissue.
To replace the belt, slide the new belt around the drive shaft of the vacuum cleaner and onto the seat. Then, replace the belt end of the roller, sliding the belt around the roller inside the plastic guides that are there to stop the belt slipping. Clip the far side of the roller back into the slots provided for it and adjust the belt as necessary to make sure that it is sitting squarely on the roller and the drive shaft and then check that the belt is tensioned properly.
Now, all you need to do is to replace the brush roller cover and tighten it down with the screws that you removed earlier. When you tighten the screws, they should be firmly screwed on, but don't overtighten the screws or you could crack the plastic casing. You can then reconnect the shark vacuum to the power supply and check that everything is working properly.
We have based this guide on the manufacturer's own guidelines, so you should have no problem with your Shark vacuum if you follow these steps.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Help on changing belt on shark rocket HV300
http://www.thinkcrucial.com/search?type=product&q=hv300
Ava B.
How do I replace belt
Ava B.
Good day! I have a fairly new, hardly used Eureka 3282 avz . Te carpet brush will not turn. How do I get that apart to try to see if it is clogged.
Flip it over. there is a plastic cover with either 2 or 3 screws that hold it on. Take these out. There is also a lip at the very front that the cover slips into. Carefully slip it out of it's slots. (Goes back together the same way) See if the belt is gone (broken) it also slips off and on it's mounts 4 easy cleaning. The roller slips out too for cleaning. Its made to do this as a regular cleaning maintenence.
1helpful
How can I disassemble the Eureka Altima Brush Roll (#60844-7) for cleaning? Thank you, Jerry in Irving, TX
You can remove the two screws in the top cover above the roller. Then lift off the top cover exposing the roller. You can then pull the roller out, and clean out the cradles that hold the end caps. The square end caps can also be pulled off the bearings at the ends of the rollers. I had a lot of stuff wrapped around mine creating a lot of drag, but the bearings were just fine once everything got cleaned out. Just remember which end cap is which, cause they're different for each end.
4helpful
2answers
Its the widepath bagged tempo, i need to change the belt but do not know how. How do i change the belt
remove 4 screws fromthe bottom of the vac. this will allow you to remobe the baseplate and expose the belt & roller. put the new belt on the roller first and then pull it to the motor shaft. Note: remove the roller and the housing under it to clean out any debris buildup. re-install baseplate and screws.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
9helpful
2answers
Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
1helpful
My dyson is making a loud horrible noise
Hi.
Check the brush roller can be moved by hand & that it is not snagging on something.
If it is difficult to rotate remove sole plate by turning the 3 plastic screws to unlock position lift plate off & clean brush roller & check you can turn it after this.
If brush roller is free to rotate the chances are the clutch is faulty & will need to be replaced.
Go to this site http://dysonmanuals.llc.nu/
It has manuals that cover clutch replacing on all Dyson models.
3helpful
5answers
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
