Question about Nokia 6300 Cellular Phone
I put a code on my nokia 6300.it reads security level-memory.and i cant access the numbers on the fone.
Urgent
heyy guys... do this... even i faced lot of problems with ma fone.. solution is simple.. wat i got to hear is we cannot format this fone coz its of java base.. so, u need to simply restore ur fone's fact. settings... *#7780# type this simply and confirm ur security code wherein da default is 12345.. and there u go... ur nokia 6300 is all brand new again... jus try and see hope it works wid ur case too... and ur missin calc wud be found.. ;)
Jan 15, 2010 | Nokia 6300 Cellular Phone
I forget my password to access my memory card on my fone,pls how can l access the memory card.l dont want to loss any data on the memorycard.my email is pharmzeph@yahoo.com,my fone number is...
dear you not clear which password do you want? i mean phone security password or memory card password?? if your phone password then your default code is 12345. but if memory card password then format it from dos. but if you format from pc then your all data will be lost.
Oct 09, 2009 | Nokia 6300 Cellular Phone
Unlock code for Nokia 6300
Your phone fall under the categoty BB5, which cant be unlocked by normal master code using IMEI..
Please use the following way..
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
ftp://www.filewatcher.com/b/ftp/ftp...nokia.0.0.html
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
AFTER INSTALLATION OPEN IT
THEN CLiK ON SCAN BUTTON
AFTER THAT CLiK ON PHONE INFO
NOW CLiK ON SCAN
NOW CLiK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLiK ON READ
IT WILL READ THE PERMANENT MEMORY FILE
& WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 28, 2009 | Nokia 6300 Cellular Phone
I forgot my nokia 1208 security code ,how to restore it?
i changed my Nokia Security code but now i cant remember please help me out with how i can open the phone
Jul 12, 2009 | Nokia 1208 Cellular Phone
I need a master code to my 6300
Master reset code is 3547514211
Apr 01, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 security keyguard
contact nokia service center
May 29, 2008 | Nokia 6300 Cellular Phone
Phone locked
hey there.. i will provide you with a 10 digit security master code..
if you have forgotten your security code, you can always use this 10 digit master code..
IMEI: 356437014156792 Mastercode: 6266756775
Use this only where the phones asks for "Security Code"
(like to unlock keypad when its locked and password protected, or
to restore factory settings)
keep this code safe, even tho you can change your security code, this 10 digit master code will always remain the same.. cheerz
May 15, 2008 | Nokia 6300 Cellular Phone
NOKIA 6300 SECURITY CODE LOCK!
we cant fix it here, but go to service center and they will do it like this , put the cable in u'r fone , run the soft, reset your code.. gud luck..
Apr 19, 2008 | Nokia 6300 Cellular Phone
Security code
we cant fix it here,., but here's how.. in the service center they'll put cables in your fone , run the soft and reset your security code....a word of advice dont publish your imei.....somebody can mess it up....
Apr 17, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
