This is a generic type answer, but, most of these washers have a pump to pump out the water. If some small thing like a hairpin gets in there it will collect lint and plug the outlet of the pump. Or the impeller to the pump may break. Access the pump, remove it, and look for the problem there. Make sure the belt drive to it is working or it will pump no water. I hope this helps. I assume you meant by "plugged drain", that no water is getting pumped out. I have seen this problem in Kenmore washers in the past.
SOURCE: Kenmore he2 washer/baffle
those are a little tricky baffles to remove u should slide them toward u should come off they are tight
