Question about Microwave Ovens
What if the wave plate of my microwave is black? Can it be fixed?
  • 999 Answers
If it is charred you will have to determine if the damage extends beyond the plate. If the part is available it can be replaced.
Eric
Posted on Jul 16, 2009
My Daewoo Micro Wave Was Spitting Flames Last Night Due To A Hole In The Wave Plate
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Sep 23, 2017 | Daewoo Microwave Ovens
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cover or...
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape.
Apr 17, 2014 | Maytag MMC5000 Microwave Oven
Hi, My AEG built in micro wave has stopped working I was warming plates and it just cut out leaving an / and * on the display, I switch it off for 15mins then switched it back onit flashed 12.00 twice and...
Your microwave is not intended for use as a plate warmer. The plates may not even be microwave compatible. You may have caused the internal fuse to open or smoked the magnetron. The control board may have been affected as well.
Jan 01, 2014 | AEG MCC663 Microwave Oven
While i was trying to prepare some coffe in the microwave after 2 minutes i opened the micro and the coffe was all over and now it's not functioning well? Can it be repared ?
Yeah a kind of. If the wave cover plate is only went bad(A rectangular plate inside the food chamber).
If you have little idea how to use voltmeter then only you can try to fix it.Otherwise,without any experience it is very risky.
First check the magnetron which produce microvave.(check two terminal resistance in isolated sysem).MAKE SURE YOU DISCHARGE CAPACITOR FIRST .MICRVAVE CONTAINS 5000V IN IT.
If magnetron is good then just clean the wave guide and replace the rectangular plate(wave cover).
it should work okay then
Thanks
Please rate my work
Sep 10, 2011 | Microwave Ovens
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
The top plate inside the microwave sparks while cooking. We checked the dish we were cooking with, the papertowel that covered the dish. What could be causing this?
The wave guide could be dirty or damaged. Dirty oven interior can also cause sparking. The wave guide is probably not dirty if it's not on the interior of the oven . Some are behind the interior wall .
Mar 28, 2010 | Whirlpool MH7140XF Microwave Oven
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
Break my glass plate inside my micro wave
You might do better to replace the microwave. My plate broke and would cost $27 to replace. I bought a new microwave for $40.
Jan 30, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
