Question about Microsoft Wireless Mobile Mouse 3000
Optical Wheel Mouse Freeze-up
Hi - while on the internet my mouse started acting up and then just wouldn't work at all. I connected another regular wheel mouse and that also is acting up but hasn't frozen-up. I did an uninstall and still nothing. I have Winodows XP Home and the mouse is a Nexxtech, Model No. NXX200. I also opened up my pc and cleaned it, but still to no avail. Can you help me, please.
clayburner
  • 1 more comment
  • DarkDynamite Jan 18, 2008
    same problem.
  • Anonymous Jan 29, 2009
    yep me also, driver conflict?
  • mousendahous May 15, 2009
    My MS Wireless Notebook Optical Mouse 3000 Model 1056 keeps freezing up. Not batterie operated, plugs into USB. Running Windows XP 2002 SP2. Had moust 6 months, just started today start behaving erratic then COMPLETELY FREEZES on ALL programs. I've "poked" the "Connect" button on bottom of mouse: Nothing. I've "poked" the "Connect" button underside of flash drive while plugged in USB: Nothing. HOWEVER, when i remove the flash drive & connect it back to the mouse (to recharge?) for 5-10 min's, THEN it works - FOR A WHILE. What could be a permanent solution?
    President:
  • 8,637 Answers
Not sure what make mouse you have. Is it a wireless mouse? If so then it probably is the double AA batteries are needing to be replaced. Bud
Posted on Jan 06, 2009
Yes. I didn't realize my cordless mouse DOES take batteries. It was difficult to find where the compartment opened up. I replaced with new, everything PERFECT NOW.
Posted on Oct 26, 2009
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
I just bought my mouse FHA-3410. i connect he usb, my red optical ligh its working, but the mouse cursor dont't works. Thanks
Sometimes if you have the optical mouse on Black pads, that can be a problem. Sounds as you have the battery in right, Have you tried rolling the wheel, to make sure it isn't out of sight? Now if you had to install software for the mouse. Take out the receiver, (USB part) then uninstall the software. Then restart your computer, then if you have the software, run it, I wouldn't put the USB part in until it tells you to, then leave it , you may also want to try a different USB port this time. Reinstall follow directions, it should work. Hope this will help you,
Jun 02, 2011 | HP Wireless Optical Mouse
Wireless keyboard and mouse freeze more and more frequently
Try pressing the green button on the mouse receiver and the green button on the bottom of the mouse. I believe that they serve to connect to each other. Mine went out when I changed the battery. Sometimes I think that my computer acts funny when the wireless parts pick up some stray signals from the neighbors. At least that happened to my garage door when the neighbors installed some new wireless computer equipment!!
Mar 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Why does my mouse freeze?
Possibly a bad mouse.  Either try another mouse on that same port or try that mouse on another computer.  If you want to, try that mouse on another USB port on your computer
Mar 07, 2009 | Logitech Wheel Mouse Optical
Optical mouse
Yes you may use your regular keyboard if it plugs into the keyboard port the the wireless mouse plug into a usb port.
Depending on how the wireless mouse/keyboard reciever plugs into your computer. it's either it splits into one keyboard plug and one mouse plug OR just on usb plug.
Mar 01, 2009 | Compaq Wireless Keyboard/Mouse p5304
My Logitech MX310 Optical Wheel mouse is not working!
Try changing battery, but if you got it in 2007 it may be time for a new one.
Oct 19, 2017 | Logitech Computers & Internet
Mouse Problems
it's possible that your connector isn't properly seated and/or getting a good connection and the large amount of mouse movement that games like Counter-Strike require could be causing it to unseat and reseat sporadically. If your model is a USB unplug and plug it back in "firmly". also you can try using a different USB port.
The reason it's taking 10-15 seconds is because windows is uninstalling and reinstalling the mouse in your hardware profile every time it loses connection. Since this is a fairly memory intensive operation as far as windows goes and you're already playing a video game (which are notorious for using large amounts of RAM and CPU time) that's just how long it's taking.
If unplugging and reinserting the cable doesn't work, your best solution would most likely be to simply go out and buy another mouse.
Jun 30, 2008 | Microsoft Wheel Mouse Optical PS/2 USB...
Microsoft  Wireless Mobile Mouse 3000  Logo
529 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
