Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi 61SDX picture got dim shows Code 3
My Hitachi 61 SDX is about 6 years old and the picture has become very dim. The Magic Focus does not work properly and after the Magic Focus flashes a few times I get a large number "3" in the bottom right corner. Does anyone know what this code means? Thanks
  • Anonymous Jun 10, 2008
    red and neon green Half moon drop down from top of screen some double eyes
  • office264 Jul 19, 2008
    it got dim no codes showing the went black if its lamp prob is there a part # that will fix it
    President:
  • 4,402 Answers
Use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a double picture on my 6 year old Hitachi Projection tv.
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Dec 11, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 51G500 big screen rear projection tv
Is this a new television? Under warranty? You need a service call.
Aug 07, 2008 | Hitachi 51G500 51" Rear Projection...
Dark Picture
The procedure for correcting dark picture is EXTREMELY dangerous.. If you're not sure about what you're doing call a qualified technician or you could seriously hurt yourself or get killed!
Picture Dark, abnormal, Changing Color Temperature
  • Clean the Spark Gaps on each CRT PWB. Remove the Cap, clean the contacts with thin fine sand paper, blow out, reseal.
  • Remove the CRT Sockets, clean the pins on the CRT. Push the CRT socket on and off several times.
Make really sure before you sttart this process that the Tv has been unplugged for several hours and that you discharge the crt as you remove the anode. There is some extremely high voltage present for hours after the Tv has been off...
Or get a reputable shop to come out and do the procedure for you - - might just save picking yourself up of the opposite wall.
Bill
Nov 20, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
285 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
