The clip on the door i glued it together . shut door with load in the washer . when done with load could not open , had hard time opening it , it did open with force, got new latch, now it d5 keeps showing will not close
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
