Question about Nokia Cell Phones
How do i open the phone up in order to replace the keypad? Do I just prise the thing out after I remove the battery or is there some finesse (or tool) required? thanks
How do i disassemble the DirecTV RC71 Remote?
Check for more screw(s) behind the label/sticker. Also, you may need to have a flat edge screwdriver or knife to prise open the remote.
Sep 24, 2014 | Directv Televison & Video
How to remove keypad on ze5730 hp laptop i have a new one want to replace.
turn the laptop over
look for screws marked with a small keyboard symbol next to the screwholes
unscrew them and note where they came from.
Remove the battery, there are six small screws that hold the plastic keyboard bezel in place, remove and note their location.
Turn the laptop over and gently, using a flatbladed screwdriver, prise the bezel loose, take care. as a small ribbon cable connects this to the motherboard.
Lift it off and ease it back.
There are now 4 screws holding the keyboard in place that can be seen, remove these and lift the keyboard up, detach the clip on the ribbon cable to motherboard (carefully).
replace in reverse order
Mar 25, 2011 | HP Pavilion ZE5730 Notebook
How to disassemble LG u8180
To disassemble your phone, please follow the steps below.
  • Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers (circled below) and unscrew the aerial.
  • Remove the 6 screws (circled below)
  • Next remove the 2 rubber stoppers & screws above the main screen (circled below)
  • Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet (as shown below)
  • Your phone should now look like the picture below. Unclip the ribbon (circled below)
  • After removing the ribbon cable (above), carefully lift the metal part indicated by the arrow above. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with what's below. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  • Your phone will now be in two parts. To open the top half of the phone and get to the screen, run your fingernail fingernail between where the two parts of the housing meet (as shown below)
  • Your phone should now be as pictured below. The circled areas indicate where you'll need to remove the speaker and ringer in order to solder them to the new screen. The screen can be lifted away from the phone easily at this point.
  • Remove the LCD and replace with new. Reverse the procedure for disassembly and it's finished.
Take care and good luck
Take note, the pictures are that of lg u8120, it has the same disassemble process as lg u8180
Oct 27, 2010 | Cell Phones
*,#,o right cursor and down cursor r not working in my cell nokia-5130 i took it to the shop they sai that its ic need to be changed what shud i do???????
FIRST CHANGE YOUR KEYPAD BEALT ITS PRISE IN INDIA HALL SEL 120.00
THEN KEYPAD ICS PROUBLEM SO CHANGE KEYPAD IC ITS PRISE IS ONLY 20.00
BUT THE SHOP KEEPER SAYS ITS PRISE 200 TO 250
IDRISH 911
Oct 22, 2010 | Nokia 5310 Cellular Phone
The tip of my AC charger broke off on the contact post of my samsung sph-a620. A new charger cannot make contact for recharging purposes. I cannot see how to disassemble the phone to access that electrical...
To disassemble the phone, you need to get he appropriate screwdrivers and follow the processes below;
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers and unscrew the aerial.
  2. Remove the screws,
  3. Next remove the 2 rubber stoppers & screws above the main screen,
  4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  5. Unclip the ribbon,
  6. After removing the ribbon cable, carefully lift the metal part. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with just the screen and the keypad rack.
  7. On the circuit board, you'll see the charging port and the broken charger that is in it.
  8. Try to pick it out with a pincher, and if you cannot, then you have to replace the charging port.
  9. Disconnect the charging port and replace it with a new one.
  10. Reverse the process to reassemble the phone back together.
  11. Take care.
Jun 22, 2010 | Samsung SPH-a620/VGA1000
Keypad locked of Google Android phone
Open and remove the battery. Replace battery and close. Hit the Power button
Mar 09, 2009 | Google Android
I need to remove front and back fascias of my 6500 classic
I had the same problem. Watch this video for full instructions.
http://uk.youtube.com/watch?v=wmtOn3KhcQI
Dec 08, 2008 | Nokia 6500 Classic Cellular Phone
Acoustic Solutions DVD600k DVD player remote has stopped working suddenly have tried different sets of new batteries no good any ideas
View the back of the remote for screws. Remove the batteries and make sure there's no screw there too. The top of the remote is clipped to the bottom. Use something flat to prise it open, and thoroughly wipe the surface of the board that comes into contact with the keypad, using a clean cotton cloth dipped in methylated spirits. Wipe also, the keypad. Give some time to dry and reassemble.
kev tech.
Jun 05, 2008 | Televison & Video
W850i keypad change
1. Switch off using power switch.
2. remove battery cover and battery. You will see two "star" drive screws at the bottom of the phone.
3. remove these two screws.
4. working from the memory card slot gently prise the cover away from the main body of the phone.
5. The key pad is now easily accessible from the front of the phone and can now be easily removed.
Hope this helps
May 28, 2008 | Sony Ericsson W850i Cellular Phone
INSTRUCTIONS TO REPLACE NOKIA 6233 FASCIA HOUSING
Yes i own 1 myself and have replaced the case 5-6 times , so here you go :
First you will need a t7 torx screwdriver , and then you remove the screws ( you can find the 2 screws were the battery is )
Once you remove them you can now take the rest of the case of BUT  , you might need a case opening tool for the part just above the battery , after that youve done it except for where the keypad is , replace the keypad and the chrome surrounding the screen you can simply take it off , Hope i helped :D
Oct 18, 2007 | Nokia 6233 Cellular Phone
Cell Phones Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
