Question about Peg Perego John Deere Turf Tractor
No live feed to dpa pump solinoid on tractor 425
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 06, 2012
Starter motor keeps running
starter solinoide or ignition barrel faulty ! try key first by rotating slightly back from engauging cranking , if no change then remove live feed off solinoide from battery and hold in place by hand at battery end then try cranking to see if it stays engauged !
Dec 27, 2013 | Ford F-250 Cars & Trucks
Tractor
Most pumps on this type of machine are vacume pumps, they will have a third pipe that connects to the engine ( usually the rocker box ) where it takes a positive and a negative pulse from the engine, if the pipe is not connected or cracked it will not work, the pump itself is normally seale and non servicable, the engine may also have a fuel shut off solinoid in the bottom of the carb float bowl, if this is faulty or is not gettinf a 12 volt feed it will stop fuel to the main jet.
Dec 07, 2012 | Garden
Husqvarna Lawn Tractor 48
The fuel solinoid is on the bottom of the carb with a single wire comeing from it, to test remove the assembly, earth the body against the engine, now switch the ignition on, you should hear a click and the centre pin in the solinoid will retract into the solinoid body, if it does not there is either an issue with the power wire to it ( should be 12volts ) or the solinoid is bad.
Apr 16, 2012 | Garden
X300 lawn tractor will not start. cranks fine, fresh fuel with stabilizer, new fuel filter, checked lines and pump, and replaced plugs. still will not fire or run
Not uncommon for the fuel solinoid to stop working on fuel bowl. You can try a small amount of fuel down throat. If engine fires for a second then its a fuel problem. Solinoid or blocked jet
Jan 29, 2012 | Garden
Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
Apr 04, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
No water to my Aprilair model 550.
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Jan 26, 2008 | Aprilaire 550 Humidifier
Peg Perego John Deere Turf Tractor Logo
55 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
