My XP system hangs when booting when I connect my new powered usb hub.
    Sergeant:
    Champion:
  • 315 Answers
Dont connect the hub while xp is booting.
Posted on Jul 14, 2009
My computer will not restore with the F11 key
Unless referring to the old legacy keyboard that you have already mentioned
Assume the USB keyboard was purchased & supplied with the Vostro 200?
If correct then it will have a USB 2.0 cable connector
Do not connect USB keyboard using indirect adapters/hubs etc.
Ensure the USB keyboard is connected directly to one of the USB Root Hub ports, (e.g. one of the rear panel USB ports) before you power on the PC
Does tapping the F2 key during boot loading allow access to System Setup (BIOS) Settings?
Ctrl+F11 will not work if you have previously done an XP Clean Install or deleted/modified partitions
If keyboard is OK then you may have to do a Windows XP Clean Install
Also note that tried to do a system restore by going into Start--> All Programs --> Accessories --> Systems Tools --> System Restore t
OR
If it is there you will have to start the computer, press F8,choose "Repair Your Computer"
Aug 01, 2013 | HP Pavilion Slimline s3700f PC Desktop
I have a nexxtech 7 port usb 2.0 hub which prevents boot to windows. Incompatible?
This hub is USB powered through your computer while you are using the first ports available. If you use ALL at once ports you will need to add the appropriate AC/DC external power adapter to supply the needed extra power.
Jul 03, 2013 | Computers & Internet
USB hub problem.i have a 4-way USB powered hub that has taken it upon itself not to rustle up every now and again on boot-up. Power LED is on but the four green LED's are out and everything connected to it...
Perhaps the problem is not with the powered USB hub but rather the USB port it is plugged into, or the cable connecting them.
Plug the USB hub in using a different USB port on your system or connecting it using a different cable to see if that makes any difference.
Aug 15, 2010 | Mini Computers & Internet
My WinXP computer doesn't recognize the drive when powered on and connected to a USB 2.0 port
Do you have the service pack update for the XP Os there is a second version. There are some othere tricks you need to try 1. only connect it to a stand alone usb not a bridge there maybe a power issue for the OS so boot it connected directly to the box not threw a usb hub. If this doesnt work Validate all drivers and system updates ( and specifie the drive,size and brand) (Good Luck)
Oct 18, 2009 | BYTECC (ME-350V3-U2) Drive Case
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
Windows will not boot
Your PC will be set to boot from USB first. Go into the BIOS and set the PC to boot from hard disk first. Respond here if you need to know how to do this.
Feb 06, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Hi-speed USB device plugged into non-hi-speed USB hub
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Jules
Aug 24, 2008 | Microsoft Windows XP Professional With...
Help scanner not working
First make sure the scanner is receiving power and is turned on. Then check the connections on the scanner and follow them to the PC. Make sure they are connected properly to the pc and that the cable has a clear path. If you're still having problems let us know.
May 09, 2008 | Office Equipment & Supplies
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Jan 24, 2008 | Western Digital My Book Essential Edition...
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
