Question about Nokia 6500 Slide Cellular Phone
Want to re-activate my mobile contract with mtnsp
Have been paying my account but still unconnected just want explanation what is going on or what must i do further. cause they have disconnect even the cell nokia 6111 that have been paid up since 2008
I have just gotten Windstream, would like to set up payments online. how do I do this?
If Windstream accepts bill pay online you will need to go online to your bank and set up BILLPAY. You will need to have your account number, etc. and input the date the payment is due. You will still need to login to your account monthly when time to pay the bill. Even after this is setup the bank will not automatically pay without you telling it to send on a certain date. Just call your bank if you need further help. They are always willing and very helpful.
Oct 26, 2017 | Computers & Internet
Billing? Ihasve many charges yo my checking account. they are not mine. can I trace the phone number they are going to?
call your bank and ask for an explanation of the billings to your account
you may even get the information if you request a monthly statement as that shows where the payments were made to
May 26, 2017 | The Computers & Internet
My C355Bee amplifier will not switch on. The power light stays on orange and won't switch to green.
This is usually called "protect mode". See the link below for an explanation. If the unit remains in this condition even after disconnecting all speaker wires, it likely will require service. Please update this if you need further information.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 29, 2011 | NAD C355BEE Amplifier
F2-02
F2 02 Toner motor connector unconnected
Content: Toner motor connector unconnected
Detail: Connection detection signal with toner
motor is OFF
Cause: Connector harness defective
Connector disconnected
Check and remedy:
Check toner motor connector for
connection.
Check connector harness to main PWB
for connection.
Check harness for broken wire.
Jan 20, 2011 | Sharp AR-407 Copier
Our 2003 Passat had a check engine light, and it turned out the coolant level was low. We brought it in to the dealership to check for a leak, and they couldn't find a coolant leak anywhere, even though...
The answer is a definite yes to the second opinion. I don't know how they mean when they say the pump is not functioning properly. It may be leaking out of the waterpump seal in which case you have an explanation for your water leak. That would be a valid cause for replacement and doing the thermostat at the same time is a good idea. However, When they did not say the cause of the leak was a bad waterpump seal I would see a red go up the pole. I would ask them for a further explanation and then top off the expansion tank and go for the second opinion. Coolant does not last forever and topping off the coolant expansion tank is not cause for concern but if it is an every day or weekly occurance then you must find the leak.
Jan 04, 2011 | 2003 Volkswagen Passat
I have a Haier room air conditioner that has been running for about a month. The E1 light comes on and will not go off. The unit cannot be powered off using the power button, only by disconnecting. After...
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Aug 29, 2010 | Haier Heating & Cooling
I opened a pay pal for the fist time to pay a dog breeder for a puppy i thought everything was ok then i get a e mail saying i exceeded my pay pal account cause pay pal charged my account $ 1.98 to see if...
That 1.98 transaction is for verification purposes only. You will be able to get the 4-digit PIN on Monday and then you'll be OK. Still, you don't need to verify your account in order to pay for that service.
Aug 28, 2010 | Computers & Internet
Nokia 6500 Slide Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
