Question about Philips 170S5FB 17" LCD Monitor
42fd9925/01 screen not turning on
I have a philips 42fd9925/01 screen and it suddenly stopped working. The led just shows solid red and using a remote has not fixed the problem I would appreciate any advice on this
    Sergeant:
    Champion:
  • 315 Answers
Does unplugging it for 5 mins and plugging it back in help?
i'd call philips support, might have to get it repaired.
Posted on Jul 14, 2009
Can't get my jumbo universal remote to work with my sam sung tv model #LN22B350F2D
You can use CODE SEARCH SETTING for the Jumbo Universal Remote. Have you tried it?
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Thanx
Jul 20, 2010 | Innovage Jumbo Remote Control
How do i get it connected to the tv? and how do u use codes i dont know how to use the codes
To get your Innovage Jumbo Remote Control connected to your TV you need to program it with control codes specific to the brand of your TV. If you know the brand of TV you have you can look up the control codes for that brand in a chart. If you don't know the brand, or if the codes in the chart do not work on your TV, you can perform the auto-search function of your remote to find the codes that work.
To search for the control codes that will work on your TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 08, 2009 | Innovage Jumbo Remote Control
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
I need the code for phillips tv i got the jumbo remote
The codes for your Jumbo Universal Remote to control a Philips television are 003, 004, 006, 008, 062, 068, 069, 074, 075, 077, 086, 087, 089, 163, 183, 184, 205, 206, 207, 208, 212, and 213.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Jul 30, 2009 | Innovage Jumbo Remote Control
I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
device.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
May 31, 2009 | RCA DIRECTV Satellite Remote Control
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Codes for jumbo remote
TV codes 0013, 0018, 0028, 0031, 0034, 0043, 0046, 0052, 0058, 0072, 0081, 0084, 0134, 0135, 0141, 0150, 0162, 0182, 0187, 0199, 0208, 1019, 1033, 1036, 1071, 1077, 1149, 1150
vcr codes 4015, 4032, 4012, 4020, 4052, 4017, 4039
Turn on device that you want to set
Aim remote at the device
Press the device button for the item you wish to program and the LED will blink once
Press and hold the set button unti the LED lights up solid red
Using the number keys, enter the 4 digit code from the list. After you have entered the 4th digit, the LED will turn off, indicating that the code for the device was recognized.
If the device powers off, test the functions for the other buttons (except OK button). If all the functions work, press the OK button to store the code. If the indicator light remains solid red after blinking 3 times the code is incompatable. You then need to restart back on step 2.
Make a note of the correct 4 digit code for future use.
COde search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Aug 18, 2008 | Televison & Video
Remote code
Looking for other codes, but while im doing that you can try
COde search function is an alternative method to programming your device without using the code list
Aug 09, 2008 | Televison & Video
Innovage jumbo universal remote
Code Retrieval
Jan 23, 2008 | Audio Players & Recorders
Philips 170S5FB 17" LCD Monitor Logo
567 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
