Question about Canon Pixma MP500 All-In-One InkJet Printer
Replacement Ink Gone WRong
I refilled the ink at Cartridge World and all the colors worked except MAGENTA. No matter what I do, it won't register. What am I supposed to do. How do I reset the chip?
Message reads, "The following ink tank cannot be recognized."
How am I supposed to resolve this?
    Scholar:
  • 71 Answers
Cartridge world gives you 90 days to return the ink tank. Take it back and get a replacement!
Posted on Nov 17, 2007
I have a canon pixma ip2770. I just had an ink refill for the first time but magenta ink won't work. I tried cleaning, deep cleaning, etc. but the other ink worked just fine except magenta. what should I...
Sometimes after a refiling they cover a small air holes on the top of the cartridge when replacing the label. remove the label completely and try again.
Also the magenta might have been to empty for a refill to work correctly. There is a lower chamber in the cartridge that air can get into and stop the flow from the top section. This link below can help in that case. http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
Apr 21, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
All colors print except the Magenta. I have run the cleaning several times to no avail. The print quality check shows black yellow and blue, not even a hint of red. I hane replaced the Magenta cartridge.
It's really hard to say without knowing a bit more.
When and how did this happen?
Did you keep the machine idle, without using it for some time?
Lack of regular use causes the jets to clog up because of dry or drying ink.
Did you try refilling the cartridge?
Not all ink is universally suited.
Are the contacts clean and unobstructed?
First of all, don't waste any more ink running the cleaning cycle. It's rarely of any use when the condition is this bad.
There is a cleaning kit available with a special cleaning solution and it has never failed for me. It's cheaper than a new ink cartridge. :)
The catch is that, you will need a used ink cartridge and you will need to put some of this solution where the ink was. Then run the cleaning cycle or even try to print.
You'll get all the little accessories, like a tiny drill bit, some syringes and a bottle of clear solution.
The included instructions are not hard to follow.
I suppose the worst case scenario will require a trip to the service depot.
Feb 17, 2011 | Brother MFC-465CN InkJet Printer
The magenta won't work. i put a new cartridge, cleaned headers, test printed. all the other colors work find but, NO magenta comes out.
This sounds like you are using an aftermarket or refilled ink cartridge. If this is the case, try putting in a new OEM magenta ink cartridge and running the deep cleaning utility 3 times. This usually clears a clogged nozzle caused by non-OEM loaded inks.
Let me know if this clears the problem. Thanks.
Sep 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
Feb 15, 2010 | Canon PIXMA MX700 All-In-One InkJet...
How to refill the cartridge
This printer takes the HP 940 cartridge. I own a Cartridge World ink refilling store and we cannot refill these cartridges yet. There is a chip on the cartridge that estimates the ink levels and shuts off the cartridge when it thinks it is empty. Any refills you find are either violating patent law with replacement chips or they are telling you to take the chip off your old cartridge and put it on the new one. This second scenario is a rip off because once the chip says the cartridge is empty, no matter how much ink is left, it will refuse to print.
Jan 31, 2010 | HP LaserJet 8500 Color Printer
Ink cartridge refill
You can't refill these cartridges yourself. Sure you can get ink and inject it in, but your printer remembers the serial number of each cartridge and how many pages you've printed with it. Because it remembers this information it turns off the cartridge electronics to prevent the use of refills. I would try to get refills for the black but not the color cartridge. I own a Cartridge World ink refilling store and we have a high return rate on the color cartridges. It seems the printers are extremely finicky about color refills. If you get a black refill and your printer won't print with it, exchange it for another one because you happened to get a cartridge with the same serial number as the last one you had. I recommend Cartridge World refills, then Office Depot brand refills.
Nov 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
AHHH I can help you! you have to reprogram the chip to tell it it has more ink. on the link that I have posted at the bottom here,go to it and scroll to the bottom of the page and you will find FREE software to reprogram your cartridge without buying ANYTHING.its all in the software please rate me FIXYA!if this is what your looking for!
here ya go!
http://www.ssclg.com/epsone.shtml
Nov 18, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Not printing magenta
Try cleaning contacts with a lint-free cloth or pencil rubber , touch the nozzle area with a cloth dampened with WATER, see if magenta appears. If nothing works, change cartridge...
Nov 07, 2007 | HP Deskjet 5440 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
