Question about Brother LS-1520 Mechanical Sewing Machine
How to thread bicor vx 1005 sewing machine?
How to thread and rethread older version vx-1005?
  • 22 Answers
Most older machines start the thread from the spool on a spool holder then the thread goes through a tension dial, on to another tension holder inside the case. Then make sure the thread is going through a lever that goes up and down with the needle, through a thread holder near the needle.
Posted on Nov 10, 2009
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Need a manual for the Bicor vx1005 sewing machine
I ordered the manual through http://www.mastersewusa.com but still do not have the download link. It has been almost a week now. The site said it would be in my e-mail in 3 hrs. Well today is day 5.
Feb 07, 2014 | Sewing Machines
Brother sewing machine model vx 1140
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | Sewing Machines
I have a Brother VX-1100. When it starts sewing the bottom thread will catch and bunch up.
have you checked to see if the thread comes off the thread take up lever
are there any burrs on the needle plate or bobbin case
it's also possible that the machine is out of time & needs to be serviced
Mar 06, 2012 | Sewing Machines
How do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
Not creating a complete stitch
The needle may be threaded from the wrong side. Newer models thread from front to back of the machine, older models will thread from right to left, It is usually determined by the positions of the needle eye. rethread the top, if this does not correct the problem thne rethread the bobbin, use the instr manual to make sure it is correct.
Oct 24, 2009 | Sew D'Lite Sewing Machines
Nesting thread on under side of material
Hello frank it sounds like you might have a bobbin case problem I would try changeing it out
Jan 25, 2009 | Brother Sewing Machines
MO -634 mechanical sewing machine problem
What does "doesnt have good sewing results" mean? Is the stitch loose? Does it skip stitches? is the tension balance off?
The serger "It doesnt sew right" rule of thumb: replace your needles, make sure they are inserted all the way into the clamp (one will be hight then the other) and orientated properly (eg. flat to the back), COMPLETELY unthread machine, re-thread!!!! re-thread!!!, check for proper threading (make sure thread is in tension discs if possible), change your thread.
Improper threading is the #1 problem causer. I cant stress it enough. Rethread Rethread Rethread!
Dec 13, 2007 | Juki MO-644D Mechanical Sewing Machine
Brother LS-1520 Mechanical Sewing Machine Logo
1,656 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
