Question about Nikon F100 35mm SLR Camera
Lost f100 dioptre adjuster
Lost f100 dioptre-can I get a new one?
  • Obertelli
    Obertelli May 11, 2010
    Are you asking about the slider switch beside the viewfinder, or have you dismantled the camera and lost the part inside which adjusts the dioptre settings?
  • 39 Answers
Yes you can, try this store.
Posted on Jul 14, 2009
Brand new and out of the box the eyepieces seem to look in slightly different directions causing a ghosting of the image. It gets worse as you zoom in to the maximum setting. I have tried adjusting all...
Return them for a refund or exchange. Either the prisms need adjusting or the eyepiece carrier yoke has got bent in transit and neither are user-fixable items.
Nikon are usually excellent, but like all such products only a small sample are quality tested during production, so it's inevitable that a few rogue faulty examples will eventually reach customers.
Aug 13, 2011 | Nikon Action Binocular
I recently accuired a pair of an/pvs-7b night vision goggles. When trying them out they didnt work. I checked the batteries already in them, there was no old crusty battery acid. I replaced them and still...
Hello, there two things that can bad. One is the oscilator with voltage multiplier or the image intensifier tube. Send to Morrison Optics Co. GB....stewbison
Nov 22, 2010 | US Night Vision Ultra PVS-7B Goggles
I was wondering about the calibrations in the center between the eye pieces' and how they are used
It's there to help you set the binoculars quickly to your own inter-pupillary distance. Just make a note of the number the pointer on the scale is at when you find a comfortable setting for your eyes and then when you next use them just set the pointer back to the same number. The scale is the angle of the yoke, and you'll often (but not always) find that the scale works on other makes and models as well to help you quickly set the binoculars up to your own preferences. The left eyepiece will also have a dioptre scale (not always accurate) so when you have sharp right eye focus, adjust the left eyepiece until you get sharp left eye focus as well.The scale on the eyepiece indicates how many dioptres (+/-) your left eye is different to your right eye. If you know the left eye setting and the yoke angle, you can quickly adjust most binos to your own comfort settings. Fixed focus binoculars are different in that they have dioptre adjustment on both eyepieces, so left eye settings from regular binos are not directly useful on fixed focus binos, but the yoke angle may still apply.
Sep 01, 2010 | Bausch and Lomb Legacy 12-1056 Binocular
My F100 will only fire in the self timer mode. Solution?
Check the selector in the front lower right of the camera. Move it to M then S, then C, then back to S. Next: you need to adjust the setting from self timer back to normal, press the mode button and check the icon select from self timer to normal shooting mode.
Apr 27, 2010 | Nikon F100 35mm SLR Camera
Adjustments seized zeiss binoculars deltrintem 8x30
Which parts are seized?
The focus wheel or the dioptre ring (the one around the right eyepiece)?
Jul 21, 2009 | Optics
Can not focus, all images blurry, no clear images
Normally this problem is caused by incorrect setting of the dioptre. This is a "focus" ring on the eyepeice which adjusts for the strength and position of the eye. Try adjusting this for best focus at about 5-10metres prior to focusing the unit.
Jun 21, 2009 | Optics
Focusing the left side
You should use also the dioptre adjustment. Especially if you're wearing glasses normally.
Focus the unit with one eye closed first. Then adjust the other eye piece so that you see clearly.
Mar 15, 2009 | Optics
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
JVC camcorder with blurred images
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
Jun 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Nikon F100 35mm SLR Camera Logo
173 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
