Question about HP Photosmart M525 Digital Camera
Hi, im getting an overexposed effect on my still shots.. almost a whiteout and then i may get a normal exposed image with a subsequent shot all my settings are on auto.. my video recordings are normal. whats my prob?
  • 390 Answers
Hi
best place to start with would be t reset the settings to factory defaults
this will set any high exposure, shutter, aparture settings that have stayed back to normal
if there is any clarification further u need then u may add a comment to this thread or may mail me mail2pvs@gmail.com
happy clicking
pls rate if this was any help
Posted on Jul 14, 2009
Over-exposed & Lines Picture problems! Please help!
Kate,
It's six years old - at $90, that represents a mere $15 per annum. Just replace it.
Jun 11, 2017 | Sony Cyber-Shot DSC-H70 Digital Camera
My Sony Cybershot DSC V1 viewfinder screen very briefly shows the taken image and this then quickly fades to a foggy whiteout which sometimes shows the ghost of the image taken. The same image shows when...
It is possible that the image sensor which is the CCD- charge coupled device is faulty and will need a replacement. However it is important that the OE part is required and so is best to take consensus with Sony spares and service.
Mar 14, 2012 | Sony Cyber-Shot DSC-V1 Digital Camera
Camera is overexposing shots. Like time or opening problem
Did you change the ISO or the EXPOSURE COMPENSATION to a higher setting?
Jan 03, 2010 | Cameras
Photos are super over exposed when using 430 Speedlite w/Canon 40D, even though the settings are per the manual
if overexposed, what yuou can try and do is make the shutter speed faster (so less light reaches the sensor) or reduce to the ISO setting to 200 or lower as needed. Both these will help with overexposed images. I wouldn't recommend consulting the manual because there are so many variables... The manual doesn't know exactly how much light there will be in very shot you take, and that is the crux of photography, working out what settings work best with the light available for each shot.
Hope that helps!
Apr 06, 2009 | Canon EOS 40D Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
White images
Camera seems got problem with CCD Imager and Sony offers free of cost repair on this. Click Sony Support to get details of free repair.
Regards,
Sep 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Powershot A75 with pink/blue streaks
I have similar problem.highlights overexposed,with streaks of pixels running vertically.overall pinkish hue
Sep 07, 2008 | Canon PowerShot A75 Digital Camera
My New CD300!
EV stands for exposure value. An indication of 0EV is what the camera thinks the correct exposure should be. If the EV becomes a positive number it means the camera thinks the image is overexposed by that amount (+1=1 stop, +2=2 stops overexposed etc) A negative value means the camera thinks the image is under exposed. I have a 707 and find the I prefer the images from it at -0.3EV, so if you're happy with the setting you have now, I say stick with it.
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
If there any way to get a properly aligned image when recording a document or some other rectangular subject that is not straight?
When the camera is at an angle to a business card, document, whiteboard, or other rectangular subject, one side of the subject in the recorded image may appear longer than the side opposite from it. This is called "keystoning," which is caused by the difference in distance from the camera lens to each side of the subject. The side of the subject that is closer to the camera looks longer and the side further from the camera looks shorter. Using the camera's Business Shot Mode automatically eliminates keystoning and gives a normal shape to rectangular subjects. Though the Business Shot Mode is able to eliminate the effects of moderate keystoning, certain conditions may make automatic keystone correction impossible. Also note that the maximum Business Shot Mode image size is 1600 x 1200 pixels. If you have the camera configured to record larger size images, recording with the Business Shot Mode will produce a 1600 x 1200 size image. When the camera is configured to record images smaller than 1600 x 1200 pixels, the Business Shot Mode will produce images in accordance with the currently specified image size.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
HP Photosmart M525 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
