Question about GE Energy Star WCVH6260F Front Load Washer
The washer locks and unlocks the door without doing anything. It will move 2x and do it again if you hit the start button. It gets the clothes wet, but that is all.
  • Michael Childers May 11, 2010
    this machine normally locks and unlocks the door then relocks automatically. When it is doing this it is doing a system check. if it never relocks you should get an error code. does the drum turn between locks? Have you noticed the sound of the lock compared to when it last completed a normal cycle, this can help determine if the lock is the problem?
We called a repair man and he said that the controller was bad. It would cost $500 to fix and he said he sees it on so many GE front loading washers. GE knows these are bad, yet won't admit it. I think it's time for a class action lawsuit (I am not a lawyer, just mad that I bought this, making life horrible for a family of 5). Will NEVER EVER buy anything with GE on it. May quit watching NBC programs. They should not be allowed to knowingly victimize working families across this wonderful country of ours.
Posted on Aug 04, 2009
Display read suds, cloths wet and waher will not spin.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not start and is making a buzzing sound.
did the belt fall off in the back of the washer. Mine was overlaoded and the belt came off somehow- it went back on fine.
Apr 17, 2008 | GE WSXH208A Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Door would not unlock - got an error code f-22 what does that mean?
well all you have to do is hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
GE Energy Star WCVH6260F Front Load Washer Logo
154 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
