How do you tell the bulb is bad
hi,
Testing suspect/broken lamps
1. As before, with lamp replacement, allow approximately 45-60 minutes cooling time before accessing the projector.
2. If there is no output from the lamp, ensure that all internal, external and trip fuses are intact and filter covers are correctly fitted.
3. If another projector of the same make and model is available, change over the lamp assembly to confirm that the lamp is at fault.
4. If the projector is now working, a replacement lamp should be ordered from a recommended supplier.
5. If the projector still fails to work, check that the manufacturer's warranty has expired and, if so, contact TRS and report the fault as normal.
6. When replacing a lamp and it is found that the glass lamp housing has shattered, be aware that lamps can contain a small amount of mercury vapour. The room should be evacuated for a minimum of 30 minutes prior to any further remedial work being carried out.
7. On returning to the room, do not attempt to clean out the shards of broken glass. The projector should be carefully placed in a robust plastic bag and sealed.
ok
