Question about Saws
What kind of grease should you use to pack around the gear in my old skill saw, model 574
    President:
  • 1,124 Answers
Some all purpose grease should be fine..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
De Walt radial arm saw old model 7740. Am trying to restore it to working condition Very difficult to change the height adjustment due to binding when trying to turn the handle on the top.
The manual for the saw is included below, To free the height it may be best to remove the saw carriage from the arm to reduce the weight.
Use WD40 or equivalent to cut the rust and a suitable grease to maintain the freedom. There is a worm screw that is below the cylinder that may need lubricating. The manual shows the assembly. I routinely apply 90 weight gear oil around the large tube where it goes into the housing,
http://vintagemachinery.org/pubs/252/1213.pdf
26351737-byjyd4kzhh1rgh2pqslbdjkq-3-0.jpeg Hope this helps?
http://vintagemachinery.org/pubs/detail.aspx?id=1213
Nov 12, 2016 | Delta Radial Arm Saw
Why is my reciprocating carver leaking black goo?
Terri, this is grease leaking from seal on col-let shaft, or loose bolts/cracked casing. Take apart and repack gears and housing with lithium grease ( do not over pack) and change seal if possible.
My old sawzall from the 1980 has started to leak
sawsall leaking grease
http://www.shopfloortalk.com/forums/showthread.php?t=24494
Feb 24, 2016 | Saws
What kind of grease for a dewalt table saw?
Hi, Dewalt is always expensive (actualy their owned by Black & Decker)
but what you need to get is a grease that has a high tempreture rating as it is for inside the geers, this is to avoid the grease drying out and going hard , go to a local Irnmonger and he should be able to advise you,or talk to a mechanic as they know about oils and grease...T.C.
Mar 19, 2013 | Saws
What kind of oil do i put in my skill saw 77
This saw requires Skil's heavy-duty, worm-drive oil, part number 80111. If you can find a local vendor that has some great otherwise, type 'skil 8011' in your search engine and shop around for an 8oz tube, they can run from $5 to $10 plus shipping.
Jan 28, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
New motor makes loud noise when operating
Use a food grade grease to lubricate the gears. The newer White Mountain freezers have Chinese made motor drives and are a piece of junk. Don't confuse the newer models with your old American built machines. If it's still under warranty contact the manufacturer for warranty repair. Read the most recent customer reviews for the 4 & 6 quart electric freezers on Amazon and other websites. You will see a rash of motor failures!
Jul 20, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
How much grease should I pack into a gear box of a food mixer? should all cogs be covered?
pack it full the grease seems to find a way to move a way from the gears after a while so you new grease and pack it in
May 20, 2010 | Hobart D300 Stand Mixer
SKIL 574 7.25 CIRC SAW LUBE / OILING
The bearing are lubricated for the life of the bearings. No lub is necessary.
Sep 03, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Boken shaft of old Craftsman skill saw
I have repaired many craftsman circular saws over the years and find that they share some parts with other brands. When sears drops a model number you must try to discover who made it for them. You did not list a model number, however when I need to identify a saw w/o the number I look at old part breakdowns and look on ebay for similar looking saws. Try and identify which manufacture made it for sears. Many were made by skill over the years so I start there. Once I find a good match, I check for available new parts. If not available, I check pawn shops and small tool repair shops for used parts, even burned out armature then have it rewound at www.eurton.com If you value your old saw take the extra time to look around, if not buy a good used saw at a pawn shop. I prefer Makita or Milwaukee good used about 40-70$; good used craftsman 20-30$, take a good look at the armature commutator and check that the arbor bearing is tight. Good Luck and email if you have questions.
Mar 30, 2009 | Craftsman Saws
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Saws Logo
226 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
