Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
No 120V output
I have a new McCulloch GF6000MK. It was runing fine until my neighbor over rev'ed the engine throttle manually with his fingers (long story). Now the generator doesn't put out 120v at the electrical rect panel.
There is a large blue capacitor in the rear of the generator.
Would that keep it from putting out 120v? It's easy to get to and easy to purchase but wasn't sure what purpose it servied.
Thanks for any help,
  • ty_warner Jul 14, 2009
    avid101:
    I failed to mention that I disconnected the wiring harness that comes right from the stator and goes to the electrical recpt panel. The wiring from the stator had (1) volt when running, thought's?
  • 3,600 Answers
Please test the following and get back to us. Repace the receptical with one from a electrial store have found that many of them turn out to be bad once you replace it retest for voltage. If it still has no voltage then get back to me by posting a responce here to this question.
Posted on Jul 14, 2009
Mcculloch 13HP 338 Cc Portable Generator # FG6000MK
How do i remove the outer cover so i can replace my recoil starter? It doesn't want to come off like something is holding it in place?
Posted on Sep 22, 2010
The engine starts fine, but why doesn't it rev when I press the trigger?
Have you checked the throttle linkage to the carb.?
Apr 21, 2016 | McCulloch Garden
Why wil my McCulloch 3200 chainsaw not start after changing the fuel lines?
There is air in th sistem. Try to use a easy starter spray can into air suply. Remuve th air filter first. That will start th engine and keeped runing untill all the air in th fuel lines is out of th sistem. Or it should have a litle finger pump u can find in th chainsw
Nov 23, 2011 | Garden
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
MY 1999 1.8L PASSAT HAVING THROTTLE PROBLEMS REVS UP DIES DOWN REVS UP DIES DOWN THE MECHANIC SAID IT WAS THE THROTTLE BODY THEY CLEARED THE CODES INSTALLED THE THROTTLE BODY AND WORKED FINE UNTIL I TURNED...
it can still cause trouble, im a former vw tech, and you would be amazed at how long they last or issues that arrise, I watched a tech install an engine once because he refused to belive radio was failed,
Jun 09, 2010 | 1999 Volkswagen Passat
Ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Sep 05, 2009 | Coleman Powermate Powermate 5000W...
Low voltage, could the brushs be going bad.  I had 120v, now it's down to 111v
How is the speed of the engine? This could affect the voltage output and will affect the frequency (Hz) output. Check the Hz with a multimeter with a Hz function for 60 Hz. That will rule out a speed problem. Then, go from there.
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
I need a manual for a homelite gas hedge trimmer HT-19 I need the factory settings for the carb. bottom out screw turn out 1 1/4 turn? Have to hold throttle wide open to run.
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Garden
McCulloch pro/mac 10-10 chainsaw owners manual & gas to oil ratio?
I have an old McCULLOCH MAC 10-10 chainsaw that takes 40-1 gas. Take the metal air filter cover off, and look on the inside of it, it should tell you all the info you need like starting it, what kind of gas etc,etc
Oct 03, 2008 | Garden
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
322 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
