Question about Xerox Phaser 8400 Laser Printer
I have no black ink print at all, all other colours are perfect but only 2 or 3 blocks of black on the test sheet
    President:
  • 2,072 Answers
Bad print head.
Posted on Jul 15, 2009
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
The colour not sharp and got vertical line when print
A reason for the non-sharp collorcould be that the ink is not dried correctly, so open the printer settings andclick at the Slow Drying Paper in the Basic tab. Thus, theprinter will let the paper to dry better.
Regarding the vertical line (and not sharp color) we could check the printquality and then align the nozzles:
Checking the print quality: 1. Print a Print Quality Check Sheet.a. Press the Ink or InkManagement key on the control panel of the machine.b. Press the up or down arrow keyto choose Test Print and press OK. c. Press the up or down arrow keyto choose Print Quality and press OK. d. Press Color (Colour) start.The machine begins printing the Print Quality Check Sheet. 2. Closely examine the Print QualityCheck Sheet. Each of the four colors is represented by a slanted square patternmade up of individual blocks. The colors should appear in the following orderfrom left to right: Black - Yellow - Cyan - Magenta. 3. Compare the print quality of theCheck Sheet you just printed with the three examples listed below:
(B) Most of the short diagonal lines are missing from one or more colorblocks
(C)Some parts of the short diagonal lines are missing from one or more colorblocks4. The display will then ask you if theprint quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem. 5. The display will then ask you if theprint quality is OK for Color. Press down the arrow key or 2 or "-" to choose No for color with the problem. 6. The display will then show StartCleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes andthe machine will start cleaning the color ink cartridges. 7. When the machine completes cleaningthe print head, press Color(Colour) Start. Another Print Quality CheckSheet will print. 8. Repeat thecleaning and the quality check process following the Step 4-7. 9. Compare thesecond or third Print Quality Check Sheet with the first one you printedin step1:o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you do not see anyimprovement on the second or third Check Sheet, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you see some improvementon the second or third Check Sheet but it's not perfect, repeat thecleaning and the quality check process three more times (totally five times).If you do not see any further improvement after that, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (C) and you do not see any improvement onthe second or third Check Sheet, repeat the cleaning and the quality checkprocess three more times (totally five times). If you stilldo not see any improvement,, please contact Brother Customer Servicefrom "Contact Us".10. Press Stop/Exit.Setting the Alignment:1. Press the Ink or InkManagement key on the control panel. 2. Press the up or down arrow keyto choose Test Print and press OK. 3. Press the up or down arrow keyto choose Alignment and press OK. 4. Press Black (Mono) or Color(Colour) start. The machine begins printing the Alignment CheckSheet. 5. By reviewing this Check Sheet,you can determine if the alignment needs adjustment. 6. Examine the 600 dpi and1200 dpi test prints on the Alignment Check Sheet. If the number 5 sampleof both the 600 dpi and 1200 dpi most closely matches the 0 sample,press the up arrow key or 1 or "+" to choose Yes.
If one of the other samples is a better match for the 0 sample, press the downarrow key or "-" to choose No. The display will thenprompt you to choose the sample that most closely matches the 0 samplefor 600 dpi and then 1200 dpi. 7. Press Stop/Exit.
Aug 04, 2011 | Brother MFC-5860CN InkJet Printer
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
    Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
    • Print a Print Quality Check Sheet.
      1. ress the Ink or Ink Management key on the control panel of the machine.
      2. Press the up or down arrow key to choose Test Print and press OK.
      3. Press the up or down arrow key to choose Print Quality and press OK.
      4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
    8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
      Press Stop/Exit.
    Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
    Black ink not working
    Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
    Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
    My copy prints come out blurry after changing ink cartiges
    Try this:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Xerox Phaser 8400 Laser Printer Logo
    75 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
