Replace toner cartridge if third party with oem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: SHARP AR163 Displaying H2 error
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE***
You have to reset fuser errors with simulation
14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it
is the thermistor, if it does not it is the lamp, but check the
contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
SOURCE: what is the meaning of f 5 error code in sharp AR163 PHOTOCOPIER
F5 is exposure lamp problem, to fix this problem try these
solutions:
Solution1: switch off and on the machine.
But if this is not working try solution2
Solution2: Step1: Press continuously Clear
key then Interrupt key then Zero key then Interrupt key
Step2: You are inside the simulation if the display turns off but if not
do again step1.
Step3:
Press 14 then press print button
Step4:
If not canceled try step1 to step2 again then press 16 then press print button
But if this is not working try solution3
Solution3: try to open the platen glass and clean the
mirrors and also the bottom side of the platen glass especially the white
correction plate then apply solution2.
