Josh Wright,
You can click the link below to purchase a Disk.
http://www.restoredisks.com/findrestoredisk.aspx
If you are still within your warranty period and did not make the backup media using the backup media icon on your computer you can click the link below.
http://dell.to/224fNxV
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: I need to reset my
Using PC Restore in Windows XP or Media Center
Notice:
Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
SOURCE: how do you reset factory default on dell inspiron
restart your computer when you see the dell screen press CTRL+F11 follow the steps.
if your computer is older then 4 years I think its F8
SOURCE: I want to restore my dell inspiron mini but I dont...
Run PC Restore from the instructions below
http://www.fixya.com/support/r3705089-restore_dell_system_original
If that fails, then you will need an External USB Optical drive to reload windows from using your Dell reinstall media that came with the system.
SOURCE: dell inspiron n5050 factory setting cd disk
If your Dell system is facing freezing/hanging problem or its performance is going down, you can easily reset/restore your Dell computer/laptop to factory setting. .....read more..how to reset dell laptop to factory setting
