Question about Garden
I have a MAC 2816 gas trimmer and need a diagram on where the fuel lines need to be connected to.
moretons
  • 155 Answers
SOURCE: GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Posted on Aug 04, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
Do you have a gas line diagram for gas trimmer
If it has a primer bulb those typically connect to the carburetor at the diaphragm with a return line going to the tank. The larger line is for the carburetor fuel feed from the tank. All lines that are meant to draw fuel from the tank will feature a filter on the end usually inside of the tank.
Jul 06, 2015 | Craftsman 25cc Gas Line Trimmer
What else should i try
Sounds like the check valve in the primer base is stuck/clogged/damaged, assuming the fuel lines and fuel filter are intact and not clogged, It will have to be replaced.
Jul 25, 2014 | McCulloch 2816 Edge Trimmer 28cc
Fuel line replacement for mcculloch 2816 weed eater
Hi Chris...
Hope this is what you need.
Please take time to rate me
Bud
Mar 31, 2013 | Garden
Model no.358791072 fuel lines were rotted.I need a diagram of the proper order
Hi and welcome to FixYa, I am Kelly.
The fuel line WITHOUT a strainer will go from the tank to the OUTSIDE primber bulb connection then from the primer bulb center connection to the carb. Item 7 this link comes with the diagrams:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791072/0247/1503820/P0808034/00002?blt=06&prst=0&shdMod=358791072
There are several you tube videos here on replacing fuel lines:
Something to note... inside the tank there is a fuel filter/strainer. Make sure to replace that fuel line also. The connection from the strainer will connect straight to the carb fuel mainfold connection. The center connection of the primer bulb will go straight to the carb fuel manifold.
http://www.fixya.com/uploads/images/1CE2BC8.gif (Expand to 200%)
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
Fuel bulb is not bringing in fuel when pushed
The larger line connects to the primer and returns fuel to tank. The smaller line has the fuel filter connected to it in the tank and connects to the small fitting on the side of carb.
Sounds like your problem is in the carb. You need to look your model up in Sears Parts because some models require replacing the entire carb.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Have a snapper snap n' go trimmer s31sng - One of the fuel lines or more were cracked and It quit running - replaced all fuel lines but don't think I reconnected them correctly. Do you have a diagram of...
I am not really sure how many lines you replaced. But the fuel line layout on most types of trimmers, weed wackers and lawn mowers are pretty straight forward. There is usually a line inside the gas tank for connecting the fuel strainer\filter. Then a line from the bottom of the tank to the carburetor. This line may also have a fuel filter located on it. On more complicated equipment you may find a breather line that loops back to the carburetor.
Below are a couple of links that might be helpful. The first three are diagrams of a similar 31cc Snapper trimmer and links to other Snapper trimmers. The fourth is to the users manual for your trimmer.
Hope this helps.
http://www.partstree.com/parts/?lc=snapper&mn=311+31cc+Straight+Shaft+Trimmer+Series+1&dn=6600
http://www.partstree.com/parts/?lc=snapper&mn=310+31cc+Straight+Shaft+Trimmer+Series+0&dn=6597
http://www.partstree.com/parts/?lc=snapper&mh=19
http://dl.owneriq.net/a/a3fbde0d-dc76-4963-935f-821589699385.pdf
Sep 01, 2009 | Troy Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,666 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
