Question about Compaq Evo N610C Notebook
Compaq Evo N610C
With power supply plugged in when computer is turned on it only stays on for 10 minutes. When turned on it shows battery stength at 97% and before it shutsdown it goes to 4%,
  • llafolle Nov 17, 2007
    Why would battery do this while plugged into AC? Does battery need to function while notebook plugged into AC?
  • 1,006 Answers
I think you have just to change the battery.It's nothing much you can do to repair it...Sorry!!!
Posted on Nov 17, 2007
I have compaq evo N610claptop, it works when plug power cable. battery also charging. but when i remove power cable computer shut down
You have to calibrate the battery.
Reboot press F10 go into the bios and look for battery calibration. Please note that it takes awhile
1 recharge
2 discharge
3 recharge
and it's done
Nov 24, 2010 | Compaq Evo N610C Notebook
Troubleshoot compaq evo n620c froze on me. Then turned black screen and will not turn off.
Unplug the power, Take the battery out and leave it for 5-10 mins. Then try and turn it back on
May 20, 2010 | HP Compaq Evo n610c Notebook
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Sep 09, 2008 | Compaq Evo N610C Notebook
No power on
cheak the all battery points.
Jun 10, 2008 | Compaq Evo N610C Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
