Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are tight. The brushes spin if held above the carpet, but upon contact with carpet it stops. Same thing on a hard surface.
  • 36 Answers
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Posted on Jul 31, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes not spinning on my Bissell carpet shampooer (pro heat turbo 2X)
Dog hair may cause this, clean this unit, take sissors and cut hair.
Feb 14, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Is the brush on the bottom suppose to automatically spin when powered on?
If its upright the brush will not turn.It only turns when in pushing position.
Jul 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9200 Proheat 2x carpet cleaner
cleaner will not start
yes, I plugged it in!
Aug 07, 2008 | Bissell 9200 Upright Vacuum
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
1,294 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
