Question about Mitsubishi WD-57731 57" Projection HDTV
Auto turn off after no screen just sound
Problem with tv shut down after 30 seconds with no picture just audio. have a lamp led but no light goes on. Manual says a momentary power fluctuation can cause this or an unusual digital signal may have been received triggering a protection circut. it's been 3 days. help
  • 7 more comments
  • Mcuff Nov 18, 2007
    Hello, Same TV same prob. Replaced lamp about a month ago... Help!!
  • Shof34 Nov 27, 2007
    My TV was working fine last night, but when I tried to turn it on this morning I have the exact same problem. Has anyone discovered a fix for this yet?
  • Anonymous Jan 01, 2008
    auto turn off after no screen just sound. The lamp light then comes on.
  • Anonymous Feb 08, 2008
    no sound just picture
  • t-bone699 May 20, 2008
    i have the same problem,tv turns on....,sound but no piture and turns off after 30 sec
  • MIKE666 Jun 26, 2008
  • martinds71 Sep 23, 2008
    Same problem no screen just sound,30 seconds later everything is off, tried to turn back on and red "lamp" light came on after blinking green turned solid
  • Anonymous Jan 25, 2009
    tv turned off with sound still on then lamp light turned on Red
  • Anonymous May 25, 2009
    same probelm
The bulb was the problem with my set.
Posted on Nov 27, 2007
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Televison & Video
AOC L32W961 No picture during initial setup problem I just bought this TV today. When I turn it on, the light turns blue, the screen says please wait for about two seconds, then the screen goes black, and...
If this is an LED set I'd look at a backlight error, some lamps in the panel are bad and the power supply is shutting down the LED supply voltage because of over current or under voltage.
Dec 24, 2017 | AOC L32W961 32 in. TV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Turn on and screen goes blank after 45 seconds
I found the problem was related to the lamp. Your TV power up but then the lamp would overheat and automatically shut down (audio and video) resulting in a dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would come back on. Then overheat, turn off - recycling "eternally". A new lamp will solve the problem
Dec 28, 2009 | Sony KV-35S45 35" TV
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Jun 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi WD-57731 57" Projection HDTV Logo
211 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
