Question about Maytag Neptune MCE8000AY Electric Dryer
My Neptune Dryer keeps giving message to "close door"
The lower cabinet of my Neptune Dryer keeps giving me the message of "close door". I have checked the lint trap to ensure it's fitted properly. Nothing seems to be amiss and yet my dryer won't start because I need to "close door".
  • 4 Answers
Call the repair number listed for your dryer and a technician will be able to come out and look at your dryer and identify the problem.
Posted on Aug 08, 2009
Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
May 05, 2013 | Hardware & Accessories
Control panel not lighting up
there is a fuse inside the machine but try to unplug it for 15 mins to reset and see what happens
Sep 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Manual on How to replace belt
  • 1
    Remove the power cord from the wall outlet.
  • 2
    Open the dryer door. Remove the screws located along the inside of the doorway with the Phillips screwdriver.
  • 3
    Pull the top part of the front panel away from the MDE5500AY dryer to disconnect it. Lift the front panel up to disconnect it from the metal clips on the dryer cabinet.
  • 4
    Unplug the wire connector leading to the door switch.
  • 5
    Unscrew and remove the four screws connecting the front panel to the rest of the cabinet. Lift the front panel up and away from the dryer to remove it.
  • 6
    Pull the idler pulley toward the left to relieve tension in the belt. Slide the belt off of the idler pulley and the Neptune dryer drum.
  • 7
    Route the new dryer belt around the drum and along the pulley system. Release the idler pulley to restore proper tension in the belt. Rotate the drum to ensure the belt is positioned properly.
  • 8
    Replace the front panel onto the dryer cabinet. Replace the four screws that connect the front panel to the cabinet of the MDE500AY dryer.
  • 9
    Plug the wire connector into the door switch assembly. Lower the front panel down into its original position.
  • 10
    Replace the screws along the inside of the doorway.
Sep 18, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Baffles are loose on my dyer maytag neptune mde5500
Hi Nick, welcome to FixYa!
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into.
Next, remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru) Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
next, look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Now you can lift up the top of the machine, and rotate the drum so that the loose baffle is at the top so you can work on the baffle easily. Rotate the drum to the next baffle, etc.
I hope you find this answer helpful.
Dec 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Flood Damage?
Do error is a Door open error code.. but if it is closed it could be a faulty door lock or a control.. check to see if you can open the door..hope this helps let me know.
Aug 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MCE8000AY Electric Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
