Question about Maytag MZD2766GES Side by Side Refrigerator
I need to change my defrost timer as the fridge side is not working
    Problem Solver:
  • 5 Answers
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time defrost the ice that is blocking airflow and causing the frig to warm. Check behind the lower panel inside the freezer.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Posted on Aug 09, 2009
How do i fix a whirlpool side by side fridge freezer. every two weeks i need to defrost, I have changed heater bar and have changed the bi metal thermostat, where is the defrost timer,
Shireen,
Some models have the defrost timer built into the control board. I worked on one that the control board was in back down near the compressor. I would suggest finding your wiring schematic and check it to see if that is the case. Hope this helps!
May 27, 2015 | Whirlpool Refrigerators
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ice accumulating behind plate inside freezer......have had all components checked, all ok, aside from perhaps the timer.......found an interesting tidbit somewhere about being able to reset a digital timer...
you may need to replace the defrost timer.the more likley cause would be a faulty defrost sensor not telling the timer when to defrost.
Part # 5303918214-Defrost sensor
Part # 240375803- Adaptive defrost timer
Jun 28, 2010 | Frigidaire FRS23R4A Side by Side...
No power & not running
Hi, you have to check few things, first of all check power at the outlet for 120 volts. If the light in the fridge works, the defrost timer, cold control and possibly the wiring are the most common things that can make a fridge sit there and be dead, not working.
The defrost timer might be stuck in defrost, turn the timer screw to advance the timer and if the fridge comes back on, replace the defrost timer. You can join the wires together to by-pass the cold control for a test, if the fridge comes on, replace the cold control...
Take care
May 02, 2010 | LG LSC26905TT Side by Side Refrigerator
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore elite Fridge not cooling (model 106.54603300)
you have defrost problem 1 check fan 2 timer 3 defrostthermostart 3 heater turn timer if heater come on change timer and defrost thermostart
Apr 06, 2009 | Kenmore Refrigerators
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
