Question about HP LaserJet P3005n Printer
Memory test failure replace dimm 1 hp p3005 - HP LaserJet P3005n Printer
    Sergeant:
    Champion:
  • 315 Answers
What is your question?
Posted on Jul 14, 2009
2 Suggested Answers
  • 11800 Answers
SOURCE: memory test failure replace dimm 0
Exactly what the message says: the RAM memory of the printer (first module - DIMM0 - to be more precise) has failed and must be replaced - it happens. It's better to take it to a repair shop, i doubt you have the necessary skills to dismantle the printer and replace the module yourself
Posted on Dec 03, 2009
Testimonial: "Thank you, Azraelsrl, especially for the very prompt answer!"
Memory failure replace dimm
I have attached the link to the manual for your printer. pages 181 to 187 refer to replacing the Dimms.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00744954/c00744954.pdf
Once you pull the old DIMM/s look for the type/size on the front of them. They can be ordered directly from HP but maybe readily available and much cheaper from places like Staples, Office MAx, etc.
Hope this helps you.
Good Luck!
Oct 06, 2011 | HP LaserJet P3005 Printer
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
Problema con impresor hp laserjet p3005, da mensaje "MEM TEST FAILURE REPLACE DIMM 0", y cuesta que en el panel de control aparezca preparado.
Hello, this error related to the additional memory installed into the printer. It could be just the memory or the Formatter board itself. The memory can can be removed quite simply.
1) Turn the power off to the printer.
2) Slide the right side cover off, moving it towards the back.
3) Remove the memory DIMM from the formatter board.
4) Turn the power to the printer back on.
Does the printer come "READY"? If yes, then the memory is bad, If NO then the formatter is bad and will need to be replaced.
A good source for part www.partsnow.com
Jan 13, 2011 | HP LaserJet P3005n Printer
Mem test fail replace DIMM1
This error indicates that either the formatter has failed, or if you have additional memory installed it is bad.
Dec 06, 2010 | HP Laser Jet Printer P3005dn
Keeps dispalying mem test faliure 1/6 replace dim 0?
Somewhat common failure code on the P3005 machines. Unfortunately this means that your formatter board has failed. Your machine MAY be repaired under warranty depending on it's warranty date with HP. Just contact HP and give them your printer model and serial number and have them check the warranty status. Trust me in what I am telling you, HP has had a large number of P3005 formatter board failures. If you want more info just do a google search on "HP P3005 formatter" or "HP P3005 dimm 0" and you will see this is a problem.
Good Luck and Thank You using Fixya.
WheatlandServices
Nov 26, 2010 | HP LaserJet P3005n Printer
Hp laser jet3005n error mem test failure replace dimm 0
This means your formatter board has failed. This is quite common on the P3005. You need to call HP support and give them your serial number. They will tell you if it is under their extended warranty. They have a program to cover these defective boards. Just don't know wether your machine will still be under that repair program. In any case be assured it is the formatter board which is under the right side cover. The one that your network/USB cable plugs into. I repair HP printers and have personally seen this exact situation 4 or 5 times.
If your still unsure just Google search P3005 formatter or P3005 replace dimm 0. You will see lots of people with the same issue.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | HP LaserJet P3005n Printer
Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Jun 02, 2010 | HP LaserJet P3005n Printer
Memory test failure replace dimm 0
Dec 03, 2009 | HP LaserJet P3005n Printer
My brand new HP LasrJet printer is displaying the message Mem Test Failure Replace DIMM. What does that mean?
Quite literally what it says. You have a fatal printer memory problem. As the printer is new call your dealer, or HP directly, to get this sorted out under replacement / warranty ASAP.
Sep 10, 2009 | HP LaserJet P3005 Printer
HP LaserJet P3005n Printer Logo
1,745 people viewed this question
Seeker5211
Seeker5211
