Question about Ezonics EZ368 Webcam
Webcam is not working on yahoo
I cant seem to use webcam when i am
on yahoo messnager
    Sniper:
  • 92 Answers
Solve your problem on link given below
http://www.camera-drivers.com/drivers/130/130527.htm
Posted on Jul 14, 2009
  • Ezonics Master
  • 10,322 Answers
1st You download Webcam Driver.
Webcam Drivers After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Ezonics Camera Drivers for Windows XP Vista Windows 7
Posted on Mar 31, 2014
Can't sing in to my yahoo messnager
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download reginout to fix the issue
Apr 11, 2011 | Yahoo Messenger
Why is it that i cant open my webcam in my ym?
If your webcam is working with other application than check the signal quality of your internet which could also result that you cant open webcam. If that is not the reason than try to reinstall webcam driver and if you facing just the issue with yahoo try to reinstall yahoo messenger..
Sep 22, 2010 | Yahoo Messenger
How do i turn it on it works with yahoo messenger but i cant turn it on i cant even find it
If you select it as the default video input device, Yahoo will turn it on automatically when you use the webcam in Yahoo.
From what you write, you might need to (re)install the webcam drivers.
Check the HP website or use a driver finder program.
Jul 07, 2010 | HP Webcam
I can cee myself when i cut onmy mini cam but i cant get it to work on yahoo
Firstly you have to install the drivers of the webcam on your PC. That you seem to have done as you can see yourself. That means that the camera is being recognized by the PC. Now to get it to work with Yahoo, you have to tell Yahoo to use this camera as default camera while you video talk. To do that you must go to Yahoo Preferences and->Video. There you must specify this camera as the default camera. Save settings. Now you would be able to video talk in Yahoo. To use it with other IMs like Skype etc, the procedure remains the same. Problem in computing is that each and everything has to be told how to do what.
Nov 19, 2009 | Logitech Quickcam Ultra Vision Webcam
How do I use my webcam?
Do you have windows vista, or XP? Try going under your control panel and searching under "webcam" or "camera". Also, if you go into and instant messaging system (AIM, or yahoo messenger), than you can just open up your webcam there. If you have any questions, please contact me at loganhrrs@yahoo.com. God bless.
Mar 29, 2009 | Sony VAIO VGN-FE880E/H Notebook
Friend cant see my webcam
Try both using the exact same version of Yahoo messenger. Sometimes different versions can give problems.
Further you can check the firewall port settings to make sure the webcam feed can pass through the internet. Some details are available in this webcam post and the comments.
Jules
Mar 05, 2009 | Yahoo Messenger
My LG S900 cam not working with messenger
Hi Rushguy55
It may be a Direct X issue.
First,
***Follow the link below to Test ur webcam using Internet explorer
http://help.yahoo.com/l/us/yahoo/messenger/messenger75/webcam/webcam-03.html
The above page will check compatibility with Y! messenger.
Minimum Requirements:
For your webcam to work with Yahoo! Messenger, it needs to support the following:
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo! Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK.
  6. Close the ampcap application.
  7. From your desktop, click “Start” and select “Run”.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under “System Information”, look for DirectX version. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
hope this helps. . .
djEnigma
Apr 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
279 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
vojvodabudva
Rommel Balcita
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
