Question about Brother HL-2040 Laser Printer
Printing mailing list
Whenever I attempt to print a mailing list from a Microsoft Word document (which was created from a mailing list merge with Excel data) to my Brother HL-2040 laser, the printer shows a paper jam error by flashing the red LED light. I have an Epson C120 printer also connected and it works fine printing to that.
I tried multiple times to print to the Brother HL-2040 by clearing the paper paths each time according to the manual and get the same error light each time.
This is on a Windows XP machine. Does anybody have an idea of what is going on and how to fix it?
  • BillP99 Nov 17, 2007
    I finally figured out the solution to my own problem after looking thru the manual again. Thick paper, and mail labels must be fed into the manual feed slot one at a time, and the blinking red light is an indicator for me to begin doing that. I'm glad I didn't buy this printer to print large numbers of mailing labels!
  • bbinstock Dec 31, 2008
    I have a problem printing mail merge documents from MS Office Word from the paper tray on my Brother HL-2040. I can print from the manual feed -- but, I am not interested in printing the numbers of pages I need to print by feeding them manually. Thankfully I have a back up printer to print these with, although I bought the laser printer with this printing in mind.
  • Brother Master
  • 1,113 Answers
Sounds to me like the word doc's page size is not set to the same as your printers tray.
In word, file , page set up. page size/paper size is set to "letter" in US I think is standard, it's A4 in Oz
On printer driver check page size setting too
Contral panel, printers and faxs, RIgHT click on brother printer icon, properties, printing preferences, page size
post back
Posted on Nov 17, 2007
  • 1 more comment
  • Soulvisitor
    Soulvisitor Nov 17, 2007
    hang on a minute...paper jam light also indicates
    - Memory Full -
    - Print Overrun -
  • Soulvisitor
    Click links above for brother info on error, see link below for paper jam error light explainations
    or could even be clean carona on drum (I think it is memory full)
  • Soulvisitor
    Yes labels do like a straight threw paper path, if they are made to turn around as paper does from a tray they tend to come off the sheet and make a mess
    Thes machines also adjust the heat in fuser to suit labels as well when you select paper type as labels or thick
    Happy printing
HP LaserJet 3050 All-In-One Printer blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
Feb 05, 2016 | HP LaserJet 3050 All-In-One Printer
I cannot find a template using Microsoft Word - Envelopes & labels for Avery label #6873.
Try this:
  • On the tools menu, point to letters and mailings, and then click on mail merge
  • Under select document type, click envelopes the active document becomes the main document
  • Click Next: Starting document.
Aug 06, 2008 | Office Equipment & Supplies
Use mail merge in Word to print only envelopes?
Have you tried going to Use this link which should call up some step-by-step demos on how to work with Word's mailmerge features.
Dec 20, 2014 | Microsoft Office Word 2007 Full Version...
How do i print a return label for contacs
If you are using a word processing program like Word or Works, you can select the "envelope/labels" which will access your contacts list (if they are compatible) and then you can print labels. You can also do a mail merge document to create labels from a list.
Sep 29, 2014 | Office Equipment & Supplies
How may I do a return address label--all 30 labels on 5160 Avery template without typing the address 30 times
Hi Jan,
You can use the option Mail Merge In Microsoft Word to print Return address.
If you are Using Windows 2003, Follow the link below
If you are using Windows 2012, You will find Mail Merge option under Mailing tab on top - Create Mail Merge option
Apr 22, 2013 | HP Officejet 6310 All-In-One InkJet...
Hi there !
For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
Here's how to create mail merge document file.
1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
6. After that, press preview result to display the datas. Save your work and it is finished
Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
How to create mailing labels in Microsoft Works
With a Microsoft Works Word document open, select: Tools>Labels>(the list of available label types will pop up, select the label sheet you're using) then select: Tools>Mail Merge>Open Data Source...
Don't know how it could be simpler.
Dec 18, 2007 | Microsoft Works 8.0 for PC
If you have Microsoft Word, you can open a template of the label you're using (which is free from Avery if it isn't already in Word) and make that document into a mail merge document.
Dec 11, 2007 | Avery DesignPro Deluxe CD-ROM...
Brother HL-2040 Laser Printer Logo
247 people viewed this question
James Cagle
James Cagle
Jim Keysor
