Question about GE Profile WPRE6100G Top Load Washer
My GE Washer washer works but the Rainse and 2nd Rainse option dose not work. It humms
  • 975 Answers
Check out the DRAIN MOTOR PUMP , usually located at the bottom on a side , where the drain hose is connected , it could be clogged with lint and debris , hope it helps, AJ
Posted on Jul 14, 2009
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
GE DISHWASHER PDW7300N10WW DISPLAY SHOWS RANDOM CODES AND BEEPS CONSTANTLY.
old post. but I am posting here, to help , searchers.
this model has a full computer behind that panel
with service modes and factory test modes.
and a service manual..
try cycling power, (pull main power plug for 5min.)
make sure the drain line is not blocked. (i use a 5 gallon bucket to test my washer drain hose. 2 person, one to hold the hose firmly in his hands , aimed at buck. (the resest button kills all actions)
the beeps are error warnings, covered in the manuals.
there are many beep modes.
even door left open, does that, soap dispenser (option) empty.
the first tests on a PDW, washers, is the rinse, only mode.
when started, it first pumps the sump dry. (old water ejected)
if the pump do dose not start, but humms.. the drain is blocked.
then does a full rinse run. if not make sure the water valves are on.
these models have a Service mode, and a factory test mode
both are covered in the service manual, and allows the manual
testing of each mode and device in the washer.
The turbity sensor can get limed up , so run 1/2 cup of vinegar
in rinse mode. once running.
GE does not offer the serv. manual to DIY, but google does find them, if you search long and hard. "for sure"
is is a generic help page, but do not down load his helper browser bad (jeckle and hyde site) the HTML pages are safe.
http://www.appliancerepair.net/ge-dishwasher-repair.html
Aug 23, 2013 | GE Dishwashers
GE washer: door won't unlock
We had the same problem and there is a wiring harness right at the door and I guess over time closing the door or the vibration from the spin cycle worked it loose. It would click and click like it was trying to lock but then the cycle would not start and it would just humm like it was trying to start the water. Make sure before you start to unplug the washer. The harness plug is on the side of the drum right at the door. If you take the bottom panel off and take the bottom two screws out and pull the panel out as much as you can you can see it there on the side. Just plug it back in and you are good to go.
Jul 06, 2009 | GE WSXH208A Front Load Washer
Washer not draining or starting cycles. Clock just humms
you have a defective timer motor or timer assembly...replace
Mar 29, 2009 | GE WBSR3140DW Top Load Washer
Water authority turned off water & washer not working now
Disturbing the water supply caused sediment to flow in and block the inlet screen(s) on your washer. Take the supply hoses off and look inside the part they screwed off of to find screens. Remove the screens and clean. Reinstall. Check that there are not filter style hose washers in either end of the supply hoses which may need to be cleaned out.
Jan 06, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
127 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
