Question about Kirby G6 Bagged Upright Vacuum
I need a shampooer tank for a kirby G six. - Kirby G6 Bagged Upright Vacuum
  • 231 Answers
You can purchase one from www.acevacuums.com
Posted on Jan 03, 2010
  • 357 Answers
  • 112 Answers
SOURCE: Kirby Shampooer
http://www.greatvacs.com/shampoo.shtml
this site has instructions with pictures
Hope this helps!!
Posted on Mar 27, 2008
  • 112 Answers
SOURCE: Kirby shampooer
here are instructions with pictures of how to put the kirby shampooer together...
hope this helps!!!
Posted on Mar 28, 2008
RockyNR1
  • 324 Answers
SOURCE: have kirby g4 carpet shampooer, need instructions for shampooer
Check out the online shampoo manual HERE
Good Luck,
Rocky
Posted on Mar 28, 2009
b0sslady2001
  • 357 Answers
SOURCE: shampooer instructions
Here is a step-by-step guide to help you out!!
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps,
Marci
Posted on Jun 28, 2009
  • 7 Answers
SOURCE: Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
Posted on Jul 11, 2009
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
There is no foam in the hose as I run the kirby shampooer. What could the problem be?
Check out the manual HERE.
It may be clogged valve on the solution tank.
Very dirty or clogged sponge (shampooer tank)
Very dirty or clogged screen(shampooer tank where hose is connected)
It is pretty common that that small screen comes out and stays in the hose elbow.
Rocky
Aug 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My kirby vac when using the shampooer doesn't distribute the solution
Make sure that the small round suds screen is in place on the shampoo tank where the hose connects to the tank.
Here is a step by step guide to help you out...
Hope this helps...
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Carpet cleaner wont foam up
My educated guess ot that the little suds screen is not in the hole on the tank where the hose plugs into it. Check to see if it is wedged sideways in the end of the shampooer hose. (this happens (OFTEN)
Here is a link to my online shampooer manual in case you need any more instruction...
Marci
May 09, 2009 | Kirby G6 Bagged Upright Vacuum
Need instructions attaching shampooer
First you must remove the power head from the front of the Kirby.
Insttuctions for this are found here...
http://www.greatvacs.com/head%20removal.shtml
Once the power head is off of the Kirby you can connect the shampooer and its tank...Instructions for the Shampooer can be found here
Hope this is helpful =)
Thank you for using Fixya!!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer
hope this helps!!!
Mar 28, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
