Question about Boating
I havw a 2005 90 hp mercury outboard that is locked up by air or some thing.I tryed to start the motor because i ran out of gas and i turned it over til the battery died i recharge the the battery and noe the flywheel will not turn at all help me
  • 74 Answers
After you pull those plugs and have in nuetral and you can't get that motor to move with the flywheel that means it's siezed
Posted on Aug 15, 2009
  • 5,546 Answers
I think your starter may have fried before the battery died. You should remove the starter and then see if the motor is seized up. Check your starter if you can jump it off the boat with jumper cables. If it spins freely then try to move the engine. Remove plugs so there is least resistence. If 4 cycle drain and replace oil, check for parts in the oil before adding fresh oil. Then see if it will turn.
Posted on Jul 20, 2009
Need a free manual for 1966 Mercury 3.9 hp outboard motor.
Don't use WD40, it is paraffin AKA coal oil
Sep 10, 2016 | Boating
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
I have 15 hp mercury hasnt been ran in two year tryin t sell when i first tryed to start it the motor would start run 1 to 2 seconds and die out thought primer bulb was bad went and bought new one then it...
my uncle told me to take the spark plugs out to check if they were dry and if they were to take a spray bottle and put gas in it and spray inside the pluggs and give it full throttle. The motor started on the seconed try.
Jan 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
495 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
