Question about Whirlpool Dryers
Gas dryer not maintaining heat.
The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob) never moves if Auto Dry is chosen (the knob does move in Timed Dry.)
I did remove the front panel plug & can see the heating elements glowing intermittently. The light cycles on & off once (not sure if that's right?)I don't know where the fuse is(even with the repair parts list I can't make it out), but if the dryer's heating at all, does that mean the fuse is OK?
  • bustd Jul 14, 2009
    The timer works using Timed Dry cycle, but the heat cuts off on that cycle, too.
    Should the light/glow be intermittent during normal use, or steady?
    70 Series Kenmore/Whirlpool 76722695
    Top Expert:
  • Whirlpool Master
  • 76,164 Answers
Have you replaced the outlet air temperature sensor?
Posted on Jul 14, 2009
  • Whirlpool Master
  • 19,396 Answers
If the dryer works on timed dry, then the fuse is surely OK.
If the problem happens only on auto dry , then the problem is either the dampness/dryness sensor, or the board connected to the sensor. On some model the sensor is connected directly to the main control board, on others there is a small dedicated control board controlling the sensor.
Regards.
G.
Runs but does not heat up, I removed the bottom from cover under the door and saw that when I turned it on the machine starts running, the thing that ignites the gas heats up to a bright redishish yellow...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 18, 2011 | Dryers
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Whirlpool gas dryer heats then stops
you will want to do two things
first check you vent exhaust even a small clogg here can be detrimental
then if thats clear
repalcce the coils on the top of the gas valve
they are probaly weakening
they are called the boost and assit
or hold and assit
they sit ontop of the gas valve
Oct 13, 2009 | Kenmore 63942 Dryer
Gas dryer not maintaining heat. The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob)...
The problem is with the 2 little circular black coils next to the ignitor. They need to energize before the gas valve can open. They tend to get weak over time. I am 100% sure this is your problem. Good luck :)
Jul 14, 2009 | Washing Machines
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Kenmore gas dryer starts to heat but does not maintain the heat. It cools down after a few minutes.
Something simple for you to try is: remove the duct from the dryer,run a cycle,IF the unit works fine, you will need to have your vent system cleaned to the outside. If you still have troubles, you will need to place a service call to have the unit diagnosed
Feb 19, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer
lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Kenmore gas dryer 110.72512101
try your pipes at the back,you may have a split
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
