Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Fuzzy picture with DVI input from NVIDIA PC Card
I have a windows XP machine with dual SLi cards. When I use the VGA input to the Philips TV/Monitor I get a decent picture. My thought was the digital output would be even better. I purchased a $50 DVI cable from Best Buy and find that the picture is much worse than the cheap VGA cable...I've tried playing with all the settings I could find but to no avail. You can barely read the screen. Any thoughts before I give up on this set as a digital monitor?
  • Pickard Nov 24, 2007
    I have the same issue:)
  • Anonymous Dec 31, 2007
    I have eactly the same problem but I bought a $5 Dell DVI cable from ebay.
I have the same TV and I found that increasing the DPI percentage (Dots Per Inch) you could reduce the fuzzy stuff, but in its still no where close to being the same quality as VGA. Hope that helps.
Posted on Dec 09, 2007
  • 476 Answers
You need to set the PC screen resolution to as neear as possible to the TV's pixel resolution - 1366 x 768
Try 1360 x 768, or failing that, 1280 x 768.
Posted on Feb 16, 2008
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Video card/dual monitor set up
If the card has dual monitor dvi out puts your set if not your going to need a new card
Apr 03, 2009 | Computers & Internet
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
Jul 18, 2008 | Vizio L37 Television
Dual monitor problem
I think you may have to use tv out as the secondary monitor
Oct 31, 2006 | Gigabyte GV-NX62TC256 GeForce 6200, (256...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
