Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a Kenmore 10657282790 side by side refrigerator. The water line in the door is leaking at the bottom hinge bracket. How do I replace this plastic line?
HVACRH20
  • 237 Answers
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Posted on Jan 08, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
BNewberry
  • 93 Answers
SOURCE: Bearing - Hinge NOISE CULPRIT ON SIDE BY SIDE?
240328203 is one bearing you need, 240457701 is the other.
They work together on the Bottom side of the door
1. To hold the door in an open position
2. To close the door when it is partially open.
240457701 screws to the hinge its called a Plate-Door closer
240328203 screws to the door its called a Bearing-HInge(Black)
Let me know how you make out. Hope this helps
Bill
Posted on May 17, 2008
SOURCE: My Frigidaire refrigerator water dispenser
I found that I have the same problem this morning. Has anyone found out how to correct it or did you have to call for service? Did they fix it?
Posted on Oct 21, 2008
lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
Posted on Jan 02, 2009
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Cold water dispenser wont stop running
Possible air leak on water tub connection. Replace water line adapter located underneath freezer door upper hinge. Let me know if that helped.
Oct 24, 2013 | Kenmore 57029 Side by Side Refrigerator
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • Jul 25, 2011 | Refrigerators
    How do i take freezer door off a side by side frig that has water/ice options
    usally a quick disconnect block for wireing harness on top freezer hing. There will be a water supply tube going up through bottom freezer hinge with a disconnect union fitting close by usally under refrig behind toe grill. once these are disconnected you can then take top hinge off of main part of refrig. by taking screws off on top of upper freezer hinge. you then should be able to lift door off by lifting up on door and water line should slide up and through the bottom hinge.
    Feb 27, 2010 | Kenmore Refrigerators
    GE Side by Side, water leak inside freezer door
    you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
    Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Replacing cam and shim
    on the right side door just take off the top hinge (three screws or bolts on the top of refrigerator) and lift the door off of the bottom hinge.
    left door is the same but you have to disconnect the water line and electric line that goes to the door. the water line has a coupling behind the kick-plate on the bottom of the refrigerator. the water line then slides up thru the hinge( BE VERY CAREFUL WITH THIS SHORT LINE COMING OUT OF THE DOOR, IT IS ALMOST IMPOSSIBLE TO REPLACE)
    Jun 28, 2008 | Whirlpool ED2FHEXN Side by Side...
    Water Leaking from the bottom of the Refrigerator
    is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
    Feb 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water coming from under door
      The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
    Oct 25, 2007 | Kenmore 50522 / 50524 Side by Side...
    Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
    94 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
