Using Illy beans, freshly ground, hard packed by hand.
SOURCE: Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
SOURCE: I bought a portafilter without the pressurizing
HI
Crema is created by pressurizing the grounds. The basket with the ring can create the pressure in the basket. If you don't have a pressurized basket, you have to make the grounds fine enough when compacted in the basket, to create the pressure. This is an art that can be mastered, but you need a real good grinder, and fresh coffee beans. Old beans won't give good crema.
SOURCE: jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
